Recieved and installed a set of VBP Calipers on my 72, non-powerbrake car. It still has perfect stock rotors riveted on. Should I use the pads that VBP sent or is there a better pad I should change to?
What kind of driving, or more specifically, what kind of ~braking~?
Typical city/highway cruising with occasional high speed?
Drag race?
Road Race?
Auto-X?
There's a pad engineered for every use imaginable. And if you manage to imagine something new, several places can custom blend for you (at signifcant cost...)
Yep, organic pads (probably what the calipers were supplied with) will be perfect for you. Good initial bite. Good wet bite. VERY easy on rotors. Cheap price. No noise.
