mastercylinder question
Old Feb 10, 2006 | 04:16 PM
itzfrank's Avatar
itzfrank
Default mastercylinder question
if the master cylinder wasn't bench bled could this cause a seal break between brake booster and m/c? I'm not sure i did it right the first time but this is my second mastercylinder and even though there is fluid in the front driver-side wheel most of the fluid leak indicated that it's coming from the m/c area. Any ideas? i'll post pictures of the leak later.
Old Feb 10, 2006 | 04:40 PM
MILO's Avatar
MILO
are sure you have the line fittings at the M/C tight enough and used a line wrench?
Old Feb 10, 2006 | 05:00 PM
Tom454's Avatar
Tom454
I disassemble all C2/C3 master cylinders before I install them. They rust internally while sitting on the shelf waiting to be adopted.
I have had a very high incidence of internally rusty -new- and rebuilt master cylinders.
The rust will cause the internal seals to fail & leak. This leak is seen between the M/C and the booster, or between the M/C and the firewall.
I only replace when the M/C is too bad to rebuild.
Old Feb 10, 2006 | 05:48 PM
itzfrank's Avatar
itzfrank
line wrench?
Old Feb 10, 2006 | 07:49 PM
gerry72's Avatar
gerry72
line wrench?
He meant lying wench.
Or, what is more commonly known as a flair nut wrench if he wasn't referring to the saucy vixen. Besides, Tom has pointed you in the right direction.
Old Feb 10, 2006 | 11:28 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
Lying Wench!
Frank,
If master should ever leak it's bad!
But I seriously doubt that not properly bench bleeding would cause it.
One thing to think about though is make sure you are not just seeing splashing from pumping the brakes with the master clyinder off!
You will get brake fluid dripping all over if you have air in the lines and pump the brakes with the MC cover off...
Old Feb 11, 2006 | 10:38 AM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I have bought a re-built MC that leaked out the rear seal after the 1st press of the pedal. Fluid ran down the booster where the MC bolts on. Eventually the booster went bad from the fluid invading inside the booster. Now I only buy NEW brake parts...no more Autozone junk ! Autozone is a pretty good OIL STORE, just don't buy any auto parts there. I love it when the parts counter boy is tapping on the computer keyboard and ask if my 72 Vette is 2 wheel or 4 wheel drive -- gas or diesel -- all while "looking" for a box of AC R44T's..
Sorry...didn't mean to get on a roll !
Old Feb 11, 2006 | 09:19 PM
bigblokvette's Avatar
bigblokvette
TOM nailed it....follow the wet stuff to it`s origin......
Old Feb 11, 2006 | 10:05 PM
big_G's Avatar
big_G
Some of those 'Zoners are about as intellegent as a box of rocks...
To mastercylinder question
