Any out there? just looking for suttle ones to add what i have done allready.
K&N'S.
crane hi-6 msd.
advanced the timing to 10 deg over the factory 6 deg btc
wot solenoid operated flap remouved from hood.
700r4 tranny with all the updates.
180% t-stat.
Runs pretty dang stout for what it is , but looking for some other budjet mods that can help.
still have original exhaust and fact ecm prom .. would any of those help?
Thank You for your help.
I've got an 82CE still have the crossfire setup.I don't think there's much out there for these engines.The guy I bought mine from had the 700R4 gone through and had all the upgrades put in,also put in a shift kit.Changed out the exhaust and went with 2 1/2" SS duals(no cats)got the K&N pretty much what you have.One question I have for you is,Why did you take the WOT stuff off for.If it makes a difference I'll do the same!!I'll just if you don't mind.I want to know the samething.
It's seemed to me like a cold air intake efect . because that flap is closed unless at wot , otherwise the only air getting is the hot engine air comming in through the small driver side intake on the air cleaner .. By taking WOT flap in the hood out that brings more cold air from the front made mine breath a whole lot better.. If you you look at it it's like a ram air efect going right into the intake. Just my 2 cent's but by doing this doesn't cost a dime and every little bit counts .
Ok,Thanks for the tip.I guess I'll give it a shot.I won't throw it away thats for sure.Been there done that and kick myself for some of the so called junk I've tossed,like a day two LT1 that I tore all the smog stuff off,thats ok just don't THROW IT AWAY!!
I yanked all of my exhaust out on my 82 from headers back, no cats. Im pretty sure I have flowtech headers to a custom made 2.5" exhaust to a pair of dynomax mufflers, true duals. It has a very low, deep idle, noticable but not to loud or throaty, a good mean sound. At WOT, however, it sounds like a freakin' race car and couldn't ask for more. You will notice a MAJOR difference once you get new exhaust on that car...
I read somewhere on the net about enlarging the (throttle body?) crossfire to allow more air to flow into the engine. Other mods were needed of course but I can't remember much more. Do a search on the web or try the crossfire forum. If my memory serves me correctly they used their existing system just machined it to a bigger bore. Then added fuel etc. Cheap mods that add up to much are hard to find.
