Vacuum Diagram
Old Feb 11, 2006 | 03:36 PM
ESC3's Avatar
ESC3
Default Vacuum Diagram
Does anyone have the vacuum diagram for a 79'?I am looking for the lines to the A/C controls.I have everything worikng off a vacuum pump but cannot find the vacuum supply line.Thanks
Old Feb 11, 2006 | 05:25 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
just guessing, but do you have an assembly manual?? i would think it would be there. also you might want to go to corvette central's sitee and see if they have any parts for the system. if they do, they often have a diagram of the entire assembly. it might help you out that way.
Old Feb 11, 2006 | 05:51 PM
ESC3's Avatar
ESC3
Assembly manual not here yet.Will check Corvette central
Old Feb 11, 2006 | 06:06 PM
cmac72's Avatar
cmac72
Mine starts on the intake manifold just foward of the distributor. Runs through a plastic reducer then a plastic reducer/splitter. One side goes foward - I presume to the lights, the other does a "T" with one line getting reduced to one of the hard vacuum lines. This line goes through the firewall to the A/C and heater controls. The source off the intake manifold also goes down on a metal tube to the transmission on the passenger side of the engine. I'm looking in my assembly manual now and will let you know if I find a vacuum diagram.
Old Feb 11, 2006 | 06:08 PM
ESC3's Avatar
ESC3
Thanks Cmac
Old Feb 11, 2006 | 06:14 PM
cmac72's Avatar
cmac72
I'm scanning in the diagram now - send me a PM with your email and I'll email it to you.
Old Feb 11, 2006 | 09:26 PM
carl a's Avatar
carl a
heres one from my 73 assembly manual...dont know if this will help or not,,,,,,,,,,,,,,,,carl-----------------------------------
Old Feb 11, 2006 | 09:35 PM
ESC3's Avatar
ESC3
I just want to thank everyone,the correct diagram has been e-mailed to me.This forum kicks A** for getting info.Thanks to you all!
To Vacuum Diagram
