Rag Joint replacement
Old Feb 11, 2006 | 10:36 PM
Hinz-73's Avatar
Hinz-73
Default Rag Joint replacement
Hi,
I have a 73 with power steering and a very worn rag joint.
I removed the two bolts that hold the rag joint to the steering wheel shaft, but can not figure out how to remove the other two "pinch studs"
Can anyone enlighten me. All help is appreciated.
Bret
Old Feb 11, 2006 | 10:43 PM
big_G's Avatar
big_G
You have to grind the head off and punch the remains thru. FWIW, I only use factory assembled couplers.... a little more money, a lot more peace of mind!
Old Feb 11, 2006 | 10:47 PM
GTR1999's Avatar
GTR1999
Big G is right,if you're using one of those rebuild kits for rag joints throw it out now and buy only the GM rag joint. Be careful about prying on the steering column too. I didn't realize I moved my column up on the 72 I'm doing until Jim Shea posted the spec for th ecloumn length. Without looking up I think it was 4.7" and the gap between the box and column end is 1.3"
Old Feb 11, 2006 | 10:53 PM
DR.Jay's Avatar
DR.Jay
Are you talking about the two studs that go through the rag paralell with the shaft? You can colapse the column to help allow removal of the rag joint.
Old Feb 11, 2006 | 11:35 PM
Hinz-73's Avatar
Hinz-73
Thanks guys.
I purchased a rebuild kit from Elkers.
Looks like quality parts.
Any other tips?
Bret
Old Feb 12, 2006 | 02:06 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I had to grind a couple of the bolts/nuts down to get everything to clear the steering box once it was assembled. Not a big deal. As far as the anti-rebuild kit paranoia, mine works just fine. The steering box and column are locked in place, so even if anything were to go wrong, the flanges would still give you minimal steering. Hell, I was steering with the flanges for quite a while, so I know it works...
Old Feb 12, 2006 | 06:50 AM
jotto's Avatar
jotto
When I did the rag joint on mine, well had a friend do it...he had to grind the heads off as described above and punch them through. If we had known, we would have bought the complete rag joint instead of the rebuild kit. We saved a few £ but the extra time and hassle wasnt worth it. Send the rebuild kit back and buy the complete joint. Just my 2 pence worth.
Also, the steering wheel moved very slightly on reassembly...not sure how as everything only fits one way! Now the steering wheel looks slightly turned when going in a straight line. PITA when parking.
Old Feb 12, 2006 | 07:46 AM
Jim Shea's Avatar
Jim Shea
The only correct way to gain enough axial clearance to remove the flexible coupling is to either remove three of the gear attaching bolts to the frame and tip the gear. Or disconnect the steering column from under the dash and pull it back a short distance.
Prying on the flexible coupling will most likely collapse the steering column shaft back into the steering column. This will not cause any sort of safety problem -- but the steering shaft is quite difficult to get back to its original length.
The reasons I am DEATH against rebuilt kits are as follows:
1). Many of the kits attach the rubber disc with just plain bolts. You must use shoulder bolts or steel bushings to create a metal to metal clamp joint when you are entrapping on a rubber part. You NEVER try and make a secure connection by just compressing rubber. NOT EVEN by double nutting, torque prevailing nuts, or Locktite!!!
2). The kits do not supply a grounding wire or supply a rubber disc with a screen molded into the face (like the production flexible coupling disc.) You may find that your horn no longer works with just a rubber disc with no ground path.
Jim
Old Feb 12, 2006 | 09:58 AM
Hinz-73's Avatar
Hinz-73
Default ..
Thanks to everyone for the comments.
I have decided to return the rebuild kit and get the replacement couplink.
Thanks again,
Bret
Old Feb 12, 2006 | 02:07 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Jim, the "Help!" brand kit I used had shoulder bolts...and it was $10 cheaper than the Corvette catalog kits. As far as the grounding thing goes, I think my horn still works. I'll check it later.
Old Feb 12, 2006 | 04:21 PM
PRNDL's Avatar
PRNDL
I recently replaced my ragjoint. Bought the replacement GM piece. I was really afraid to mess with the steering column and thought it would be easier to move the box. Well, I couldn't even reach the bolts that hold the box (I have headers - they were in the way), but I found it was quite simple to unscrew and gently pull back the steering column. I just followed Jim's instructions and was very careful. I even pulled it and put it back twice because I had the coupling on wrong the first time.
Everything went back together fine, but unfortunately like jotto my steering wheel is not centered. Small irritation, and I will fix it soon. With my 68 style steering coupling, the column end is full round, so it can fit into the coupling turned off center.
Old Feb 12, 2006 | 07:03 PM
Jim Shea's Avatar
Jim Shea
I just finished a paper on steering wheel centering. Here is the link":
http://jimshea.corvettefaq.com/wp-co...ngC308FE06.doc
You may not need it. But if you have any comments let me know.
Jim
Old Feb 13, 2006 | 02:29 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Now that I think about it, I think my rebuild kit had a bent metal "spring" that went across two of the bolts to provide a ground path. I'll see if I can get some pics of the sucker tonight.
Old Feb 13, 2006 | 06:10 PM
goinbroke's Avatar
goinbroke
Jim
Jim, that is some great info in that paper. It may help clear up some nagging little problems I've been dealing with.
Thanks for sharing that....
Old Feb 13, 2006 | 10:44 PM
MidShark's Avatar
MidShark
Thanks, Jim. I just printed it off and put it in my Corvette Library.
Rich
Old Feb 13, 2006 | 10:54 PM
GDaina's Avatar
GDaina
I think it's easier to move the steering box rather than the column.
Old Feb 14, 2006 | 05:35 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I disagree 100%.
To Rag Joint replacement
Old Feb 14, 2006 | 09:28 AM
GDaina's Avatar
GDaina
Originally Posted by I'm Batman
I disagree 100%.
I bet if we had a contest who could replace the rag joint in the shortest time, from start to finish, I would win. I've done it both ways, and dropping the box is easier on my back.
Old Feb 14, 2006 | 02:14 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm more flexible The column is lighter and I find it easier to get to the bolts. Reinstallation is a bit of a PITA at the firewall.
Old Feb 14, 2006 | 02:43 PM
jotto's Avatar
jotto
Thats the way we did it...fairly easy, all came apart with no major issues...
