Misfiring?
Old Feb 12, 2006 | 06:12 AM
enkeivette's Avatar
enkeivette
Default Misfiring?
I posted about this in another thread, but it is a separate issue.
I tried to tune my carb/ dist again today with little luck. I moved the base timing up to 16 degrees (sounds like it wants even more) and I rev the engine to see if I hear detonation and now the engine stumbles at 3K rpm. It feels like my rev limiter is set at 3K rpm and when it hits 3K rpm the tachometer freaks out and jumps to 0 rpm for a second. What's going on? I back the timing off to 14, then 12 degrees and I have the same problem.
Is this a misfiring problem? If so what causes it?
I hate messing around with tuning, I'd rather pull a trans or an engine any day of the week.
Old Feb 12, 2006 | 07:07 AM
kb2fzq's Avatar
kb2fzq
I assume you have an after market dist?
What is it?
Old Feb 12, 2006 | 04:54 PM
enkeivette's Avatar
enkeivette
MSD Pro Billet HEI, I set the rev limiter at 6750.
Old Feb 13, 2006 | 03:48 AM
enkeivette's Avatar
enkeivette
Could it be that the plug wires are too close together and the spark is jumping from one wire to the other?
Old Feb 13, 2006 | 03:55 AM
Thmprr's Avatar
Thmprr
Have had this problem on a car fitted with an MSD Pro Billet Distributor, drove me nuts, blaming the Distributor, then found that it was the MSD Coil mounted horizontally incorrectly, it has an oil filling so must be mounted vertically.
Old Feb 13, 2006 | 04:31 AM
enkeivette's Avatar
enkeivette
I think the coil is internal with an HEI.
Old Feb 13, 2006 | 05:30 AM
kb2fzq's Avatar
kb2fzq
We went thru this recently with another member...he had a light show going on under the hood in the dark....turned out after putting on copper core wires, the sparking and misfire went away....this would be my suggestion...
Old Feb 13, 2006 | 03:18 PM
enkeivette's Avatar
enkeivette
Are the MSD 8.5 mm wires copper core?
Old Feb 13, 2006 | 03:40 PM
kb2fzq's Avatar
kb2fzq
This...I confess I do not know...I'll find the thread and post it and you can read what he went thru...ah, here it is...
http://forums.corvetteforum.com/show....php?t=1286074
To Misfiring?
