flywheel?....flexplate?
Old Feb 12, 2006 | 07:00 AM
kb2fzq's Avatar
kb2fzq
Default flywheel?....flexplate?
Maybe I'm showing my age, but I have a question about parts/terminology...
Back in my "younger days"...as I remember with an auto tranny, we'd bolt the fly wheel to the crankshaft, then bolt the tranny to the block, then turn the torque converter until the tabs lined up with the flywheel...install bolts and nuts...tighten, install cover, shifter and lines and go...
On a previous thread there was a reference to a flexplate on an auto tranny...am I confused, or is there a part missing in my description...or is this new world terminology...
(Thought the flexplate was only on a manual tranny)
Old Feb 12, 2006 | 07:05 AM
PatsLs1vette's Avatar
PatsLs1vette
a flywheel is for a stick and a flexplate is for an automatic
Old Feb 12, 2006 | 07:30 AM
kb2fzq's Avatar
kb2fzq
OK...I'll get my cane, seeing eye dog and Alzhiemer's meds and go from here...
Thanks...
Old Feb 12, 2006 | 09:25 AM
redvetracr's Avatar
redvetracr
Thanks...
I think it`s called a "senior moment"
...redvetracr
Old Feb 12, 2006 | 09:50 AM
Bob in Dallas's Avatar
Bob in Dallas
If you really want to let your age show, some early automatics (PG and 4 spd Hydromatic, etc) had cast iron flywheels before flexplates came on scene.
Old Feb 12, 2006 | 09:53 AM
gerry72's Avatar
gerry72
Flexplate is largly an aftermarket term.
Most OEMs, like not Chrysler, call the round thing that bolts to the back of the crankshaft a flywheel whether it's for a manual or automatic. Such as Flywheel, automatic transmission. This consistency ensures that everyone in engineering is talking about the same thing.
So, for an automatic, either flywheel or flexplate is correct usage.
Old Feb 12, 2006 | 12:50 PM
copter's Avatar
copter
Old Feb 12, 2006 | 01:22 PM
Ironcross's Avatar
Ironcross
Not exactly are they one and the same. Part of the problem of what to call it is that Chryslers with automatics have the ring gear on the converter and not the flex plate as does GM and Ford.
Old Feb 13, 2006 | 05:25 AM
kb2fzq's Avatar
kb2fzq
Well...maybe I'm not having a senior moment afterall then...all I remember is, if somebody said, "go over to the bench and grab the flywheel...", I knew what it was and what it was for, regardless of what it's official name was, well back in the early 70's anyway...
OK...don't want to make this a 500 reply thread, just wanted some clarification on the most recent terminology that I read...
Thanks, guys
Old Feb 13, 2006 | 06:07 AM
comp's Avatar
comp
To flywheel?....flexplate?
