78 power steering belt alignment
Old Feb 12, 2006 | 12:12 PM
toupstrio's Avatar
toupstrio
Default 78 power steering belt alignment
My power steering belt looks like its way off. It is cocked at a bad angle, everything looks tight and I cannot see why its like that. Does anyone else have a belt like that?
Old Feb 12, 2006 | 02:03 PM
big_G's Avatar
big_G
The pump mounting brackets are probably bent from years of stress. You can try to correct the angles, or replace them.
Old Feb 12, 2006 | 02:28 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Does your crank pulley have 3 grooves? Power steering belt should be on the forward most groove.
Mike
Old Feb 12, 2006 | 05:30 PM
toupstrio's Avatar
toupstrio
Mike
Yes it has 3 grooves and it is on the front.
To 78 power steering belt alignment
