Got the Heater Core Out
Old Feb 12, 2006 | 03:46 PM
79vetter's Avatar
79vetter
Default Got the Heater Core Out
It really was not a bad job. It just takes time and patience. I'm happy to assist anyone that is planning on doing this job. The biggest problem is removing the dash panel because of its tendency to crack when pulling it out- very brittle. I did crack mine a little bit but its not too bad.
Question: Where do you guys like to buy your replacement cores from??
Autozone- $35.99
Napa- $57.00
O'Reilly- $35.99
Obviously I want a good one that won't throw up in the car
Old Feb 12, 2006 | 04:02 PM
Richard Cooper's Avatar
Richard Cooper
I got mine from Auto Zone 3 years ago and so far its been fine. Actually I get most of my vette parts from them. I have an 81.
Old Feb 12, 2006 | 04:09 PM
ESC3's Avatar
ESC3
Make sure you check all your vacuum lines and actuators while you are in there.You don't want to do this twice.And the Dash goes back in alot easier than it comes out.pulling the Dash out was the worst part I found.
Oh yeah,I got mine from NAPA.Check to make sure they match,mine was off slightly,but works ok for a driver.
Old Feb 12, 2006 | 04:58 PM
79vetter's Avatar
79vetter
So how does one go about testing the actuators when you don't have any vacuum to work with?
Old Feb 12, 2006 | 06:16 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
If your heater core has a clamp that holds the two tubes in place, make sure the heater core fits snug in the housing. A lot of aftermarket heater cores have output tubes that are not formed correctly and the stress from the clamp will cause them to leak.
You can get a hand held vacuum pump from any auto parts houses. Get the plastic one, I think they are $15-20.
Old Feb 12, 2006 | 06:26 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
did you test the new core?
Old Feb 12, 2006 | 06:47 PM
GaryS's Avatar
GaryS
Definetly have a rad shop test the replacement core. There are numerous reports of "made in China" cores that leak from the get-go.
Gary
Old Feb 12, 2006 | 08:02 PM
ESC3's Avatar
ESC3
$15 autostore vacuum pump.
Old Feb 13, 2006 | 01:11 PM
bluesilver82's Avatar
bluesilver82
Im about to do my heater core in my 82. I may have questions when I get in to it.
To Got the Heater Core Out
