turn signal help.
Old Feb 12, 2006 | 03:57 PM
36chambers's Avatar
36chambers
Default turn signal help.
all of my turn signals work except the rear side lights. i have replaced the bulbs but dont know what else to do. is their a fuse just for those lights? also if i put my head lights on while i am in park the lights will glow but when i hit the blinker they do not. one more is also not right; when my head lights are on the right green arrow stays light even if when i dont have my turn signals on. when i hit the right blinker it will flash. any assistant would be appriaciated.
Old Feb 12, 2006 | 08:32 PM
36chambers's Avatar
36chambers
Default no one with any advice on turn signals?
please help
Old Feb 13, 2006 | 06:19 AM
kb2fzq's Avatar
kb2fzq
It sounds to me like you have a ground problem right at the bulb sockets...buy or borrow a volt/ohm meter, and check resistance (ohms)from the bad sockets to frame...there should be no resistance....if there is, the socket has a bad ground connection...being the fenders are fiberglass, there should be a ground wire to frame on each socket...clean and reattach and things should improve...if not, we'll look a little deeper into the problem...
What year is the vette?
Old Feb 13, 2006 | 06:49 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Old Feb 13, 2006 | 01:57 PM
jdp6000's Avatar
jdp6000
Sounds like you have installed the wrong bulb on one of the right side lights.
Jim
Old Feb 13, 2006 | 10:36 PM
redcar1979's Avatar
redcar1979
Sounds like a grounding issue to me. Good luck.
Old Feb 14, 2006 | 02:04 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
[QUOTE=redcar1979]Sounds like a grounding issue to me.
Old Feb 15, 2006 | 09:38 PM
Bald Head Fred's Avatar
Bald Head Fred
Old Mar 13, 2006 | 02:57 AM
johnnybrewmeister's Avatar
johnnybrewmeister
sounds like the same problem for my '73 ('tho on the left side). L doesnt' blink, and stays "on" on the dash display. I'll check the ground and see what's up. All used to work fine up until a few months ago, so I don't think a wrong bulb is installed. Thanks for the info.
Old Mar 13, 2006 | 08:21 AM
mdj21's Avatar
mdj21
if your light is staying on, that sounds like a diferent problem.
you should try replacing your turn signal flasher.
Old Mar 13, 2006 | 02:54 PM
OddBall's Avatar
OddBall
I through in a new pair and it cleared everything up
To turn signal help.
