adjusting shaft rockers
Old Feb 12, 2006 | 04:45 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default adjusting shaft rockers
So I have these shaft rockers.
Since they are on a shaft, I am assuming that I raise the base assembly till the geometry looks right.
with nothing under the base it looks way to low. as the rockers are tilted "up" to the valve stems. I am assuming that the rocker should be fairly flat. Also I think this would be best for the push rod. How far off am I?
