Bending headers need opinions
Old Feb 12, 2006 | 10:32 PM
70 LS1's Avatar
70 LS1
Default Bending headers need opinions
I picked up a set of LS1 Camaro headers for super cheap and they look like they are close to fitting. I need to move the passenger's side collector over towards the car's centerline a little bit. I need to do the same for the driver's side.
My thought was to heat up and bend the primaries near the head flange. A small bend here will move the collector over quite a bit. I was thinking of laying the header on a 6" diameter or so pipe. Then heat the primaries and apply pressure on both the collector and the head flange This should stretch the metal and allow it to bend without crimping.
What do you think?
Old Feb 12, 2006 | 10:57 PM
GDaina's Avatar
GDaina
I don't think so...you will kink the pipes
Old Feb 12, 2006 | 11:13 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Just cut it off and reweld on a new collector. There not that expensive. I weld one collector on this weekend and it takes about an our. The hardest part was cutting out that center piece of metal.
Old Feb 12, 2006 | 11:20 PM
70 LS1's Avatar
70 LS1
Since I can't weld, I was trying to avoid that.
Old Feb 13, 2006 | 01:00 PM
70 LS1's Avatar
70 LS1
Anyone else?
Old Feb 13, 2006 | 01:08 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
BFH?
Drive over them with the car?
Old Feb 13, 2006 | 02:18 PM
norvalwilhelm's Avatar
norvalwilhelm
Welding is the only way. To bend it is useless, Heat will not do it.
Cut the collector off where is is round, not a the pipes, cut it on a slight angle and then rotate the cut off piece until the end points to where you want it to and reweld. It is really simple, takes anyone with a mig welder 15 minutes maximum and you have a nice set of headers.
Look inside this collector and you will see the joint. I did the same thing
Old Feb 13, 2006 | 03:48 PM
70 LS1's Avatar
70 LS1
The problem isn't that the collector points in the wrong direction. The entire collector needs to be moved over an inch or so. I guess I could have someone piecut near the head flange after the pipes bend downward and reweld them. Just trying to avoid welding.
Old Feb 13, 2006 | 06:06 PM
norvalwilhelm
Is it really worth it?? Hedman headers are cheap. Check out summit. I like my hedman headers and after more then 15 years I decided to replace them only because they must be getting tired and I might blow out a pipe.
Old Feb 13, 2006 | 09:51 PM
70 LS1's Avatar
70 LS1
Unfortunately no one makes headers for a C3 with an LS1 engine. That is why I am going to modify the ones I picked up. I'll post my results good or bad.
To Bending headers need opinions
