I just looked at their web site and couldn't find one for a big block. Small block yes, big block no. However they did list one for a 65 with big block (396), and its the same as the small block. Do they use the same mounts? I know the frame is the same. I just assumed with the larger mass that their would be a differently designed motor mount.
that is the same mount I used for my small block in my 81.
are the motor mounts the same for all chevy V-8's?
LS-Five that number according to summit does not work on a 454, if it worked for you I might just order it
I'm sure someone else will chime in on this, but... I believe I got that part number from someone else here on the forum when I was doing my drivetrain swap last winter.
From what I can remember there are basically only two styles of mounts, and I think they call these the "short" style. The P/N that I gave you was lifted directly off my old reciept from Summit and those were the exact mounts I used for my 496. Hope this helps.
