Dyno Day!
Old Feb 13, 2006 | 04:05 PM
Taijutsu's Avatar
Taijutsu
Default Dyno Day!
I finally made the trip to the Dynojet Dyno. First baseline run was 202 HP & 266TQ. Finished w/280 HP & 314 TQ.
350 +.60 TFS heads, Air Gap, Demon 650VS, 218-224 HR w/1.6 RRs, stock rams horns and dented duals.
Car was jetted down 2 sizes from stk w/68/76 as per Lars.
The baseline was scattered below 3K due to lean condition + too much advance (manifold vac). Went to larger squirter, port vac and #86 jets on sec. Engine ran best on 32* total.
TQ was 313 from 3800-4100, Hp started flattening out @5K 275 HP and peaked @5400 w/279 HP.
Dyno operator felt that ex was holding combo back 25 RWHP. I'm happy so far. I hope that headers and duals are worth more than 25 HP?
Still a little weak off idle @800rpm. I'm going to raise idle and drive it for awhile! MPG seems better, a road trip will tell the truth!
Rick
Old Feb 13, 2006 | 04:19 PM
comp's Avatar
comp
Old Feb 13, 2006 | 04:45 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Thats a pretty good set of gains from just tuning. Headers and duals will help out some too.
Old Feb 13, 2006 | 04:49 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Which Trick flow heads were you using? What's the lift on your cam? What's your compression ratio? Details, man, we need details!
Those are awesome numbers! I'm thinking I may have to do a head swap to get the 300 hp at the rear wheels like I want.
trw
Old Feb 13, 2006 | 05:04 PM
gkull's Avatar
gkull
Rick - Did it really take 86 jets? Were you running a sniffer on the pipes? My 750 speed demon only has 82's on the secondary and the sniffer kept mine at 12.8 A/f at WOT. That is at my altitude. But sea level only is a jet or two at most for sea level.
Headers for sure!
June is the All Vette drags at Sacramento raceway!
Old Feb 13, 2006 | 05:15 PM
Taijutsu's Avatar
Taijutsu
George: I couldn't believe it either. After baseline things, he put it on the sniffer and it can almost pass smog. After the printout from 1st run, operator says that a 10 point increase in jetting was needed. Who am I to tell him his business. He thinks I might have major backpressure w/stk ex and smashed pipes. I was hoping for 325 RWHP w/headers!
He must be doing something right, had some very nice rods waiting to be worked on. Time will tell.
Rick
Old Feb 13, 2006 | 05:58 PM
gkull's Avatar
gkull
I'd like to see the A/F ratio graph during the final run. Generally headers tend to lean out the A/F ratio. It all has to do with better cylinder scavaging. Just headers with muffler to uncapped headers at the track my pipes would turn white unless I rejetted a size bigger.
Not every carb designed is the same. But I'm convinved that you want to run your secondaries within 6-8 jet sizes of the primary side. The primary has smaller jets because of the idle circiut and the power valve etc giving it a lean cruise and additional fuel to equal the richer jetted secondaries.
Old Feb 13, 2006 | 06:10 PM
Taijutsu's Avatar
Taijutsu
George: The final AF is between 13-14. I asked about the 6-8 size difference on jetting. He said that it is ballpark not final. He left primary at 68 but went bigger on squirter from 40-45. He also played w/secondaries spring, ended up w/std spring. If he messed up, I can't tell.
Rick
Old Feb 13, 2006 | 07:18 PM
Taijutsu's Avatar
Taijutsu
Sorry, I forgot to mention that a carb w/vacume sec like my 650VS sometimes needs extra jet. Something about more fuel to make up for what the vac sec isn't giving it. I bet that mech sec follow the rule much better. I hope that explains it?
Rick
To Dyno Day!
