Four bolt main
Old Feb 13, 2006 | 09:49 PM
canucbuck's Avatar
canucbuck
Default Four bolt main
Over the past year I nave read alot and learned alot about vettes. But I would really like to know what the real definition is between a four bolt main and a two bolt main????
Old Feb 13, 2006 | 09:52 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
UHHHH! 2 bolts
Old Feb 13, 2006 | 09:56 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Sorry about that, I'm such a smart azz sometimes. There are 4 bolts holding the main bearing caps vs 2. I for one question how valuable this is for the average driver and hot rodder. My 454 build is a 2 bolt main and I am sure if something fails it likely won't be that.
Old Feb 13, 2006 | 10:47 PM
carl a's Avatar
carl a
you'll probably hear a lot of people hear say how much better 4 bolt mains are compaired to 2 bolt, remember the 327/350 h p motors or the 60's ---------2 bolt
Old Feb 13, 2006 | 11:03 PM
jerrylee's Avatar
jerrylee
Default 2 or 4
is there an easy way 2 tell if u have 2 or 4...thanx....
Old Feb 13, 2006 | 11:06 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
yep just pull the oil pan actually most people say you can tell by the engine stamp number but i have seen to many cases where that has not been the case so to say for sure the only way is to pull the oil pan and see for your self.
Old Feb 13, 2006 | 11:16 PM
Cory1970's Avatar
Cory1970
4 bolts are stronger than 2 bolts. 2 bolt mains are fine for anything up to the 400- 450 hp range. 2 bolt blocks that are splayed for 4 bolts are even stronger than 4 bolt mains.
Old Feb 14, 2006 | 07:20 AM
Tom454's Avatar
Tom454
On a factory Chevy smallblock, the crankshaft is held in by 5 saddle positions. Each saddle position is two parts: the block side, and the cap. The block side is a cast part of the block, the cap side is removeable so the crank can be installed/removed. On a small block Chevy, the middle 3 caps can be held in by either 2 or 4 bolts, depending on application.
Truck blocks and high performance passenger car blocks were commonly fitted with the "4 bolt" blocks.
The best way to tell for sure is to drop the pan & look at the main bearing caps. Yes.... some 4 bolt main blocks can be identified by reading the casting information, but I've seen exceptions even then. So if you really want to know for sure, the best approach is to drop the pan & take a peek.
This is only for the factory SBC.... others (e.g.- some factory BBC) have all 5 mains with 4 bolts.
To Four bolt main
