Norval......
Old Feb 14, 2006 | 04:26 PM
mrvette's Avatar
mrvette
Default Norval......
Could you check your email please, and get back to me...
sent you one off the 'other' forum....
need pix or 2 of your installed hydroboost, and some advice...
GENE
Old Feb 14, 2006 | 05:54 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
By all means those pics should be shared with the rest of us, not just a single e-mail :
Old Feb 14, 2006 | 06:09 PM
mrvette's Avatar
mrvette
Smoked, I thought he posted them here in a thread recently, but I did a search and can't find them...dunno...someone did, but I dunno....maybe I start another thread now....
GENE
Old Feb 14, 2006 | 06:24 PM
SmokedTires
St. Jude Donor '05
Thanks, I like to save any pics for later reference when I get around to a certain project
Old Feb 14, 2006 | 08:08 PM
norvalwilhelm's Avatar
norvalwilhelm
GENE
Blackrat is the guy who posted alot of pictures. I haven't. Don't have many
Try Blackrat he has lots. Do a search.
Old Feb 14, 2006 | 08:11 PM
norvalwilhelm
This should answer all your questions
http://forums.corvetteforum.com/show...961&forum_id=3
This has lots of pictures
http://forums.corvetteforum.com/show...367&forum_id=3
On line building
http://forums.corvetteforum.com/show...780&forum_id=3
Old Feb 14, 2006 | 08:54 PM
evalu8r's Avatar
evalu8r
Norval,
I like your new avatar pic.
Chris
Old Feb 15, 2006 | 04:13 AM
mrvette's Avatar
mrvette
Thanks, Norval, what was there was very similar to what I came up with,...I was mystifying about that slot/tab/bolt to keep the hydroboost from rotating, I allready figgered it out by time this was all posted...I just clamped the hydro b rod in a vice and cut 3/8 24 threads on it with a die, and screwed on the old booster fork works like a charm....I will put some locktite on it,
my only concern is mounting that unit, I dunno what to secure the bolts to the inside of the firewall with, as I want studs facing out...to make furure service easy....what a PIA...had to tear out the entire dash assy for nothing....not that mine is hard or anyting due to being highly modded, course I can't even see that clevis pin with everything together anyway....
GENE
Old Feb 15, 2006 | 09:11 AM
norvalwilhelm
GENE
Gene you will find if you remove the 4 studs from the mounting plate they will press into the firewall. I just removed the studs, put them from the inside of the firewall facing out then using a larger nut and the original nuts pulled them into the firewall, they are splined and this spline fits the stock firewall holes for a press fit.
To Norval......
