Trim ring install tips?
Old Aug 10, 2001 | 02:38 AM
rickclk's Avatar
rickclk
Default Trim ring install tips?
I've rebuilt my suspension, pulled the engine and re-done the complete interior in my 71, but can't put the wheel trim rings on. They are NOS types so I don't want to bend them.Any tips to installing these things would be great. Thanks Rick
Old Aug 10, 2001 | 04:10 AM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: Trim ring install tips? (rickclk)
they are a pain-in-the-foot to remove or install. a rubber mallet works good, just go easy and work the clips on succesively
Old Aug 10, 2001 | 04:12 AM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: Trim ring install tips? (Turbo-Jet)
umm, either i'm way overtired, or i really did type foot instead of foot.:confused:
HEY! ok, i get it, i can't type foot. (ha i did it) thought is was going nuts! :crazy:
geez, you can't even type 'a $ $'...
time for bed for me
[Modified by Turbo-Jet, 12:13 AM 8/10/2001]
[Modified by Turbo-Jet, 12:14 AM 8/10/2001]
[Modified by Turbo-Jet, 12:15 AM 8/10/2001]
Old Aug 10, 2001 | 09:31 AM
Alwyn678's Avatar
Alwyn678
Pain in the Foot is right sometimes......b
ut a rubber mallet will work and NOOOO dings to the rings :cheers:
Old Aug 10, 2001 | 10:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I use a rubber mallet on trim rings and center caps. On original 4 clip trim rings, I align the ring at the valve stem. I then make sure the closest clip is in the correct position on the rim and pop it on lightly. At that point I check the positions of the three remaining clips, make corrections if needed, and pop them down. I usually go back and make one more pass with the mallet over each clip.
Old Aug 10, 2001 | 12:04 PM
majglc's Avatar
majglc
I did the same as Easy Mike except I used the side of my fist instead of the rubber mallet.
Old Aug 10, 2001 | 12:16 PM
Tex71BB's Avatar
Tex71BB
They're such a pain in the you-know-what, I just ordered aftermarket rings that don't use the clips. I'll put my originals away in case I ever want to take it to Bloomington :rolleyes: .
Old Aug 10, 2001 | 01:28 PM
Easy Mike's Avatar
Easy Mike
I do the same as Tex71BB -- I store my original 4 clip rings until I feel a need to impress someone. For all other purposes, I run the stainless steel aftermarket vari-clip rings. It's the best of both worlds.
Old Aug 11, 2001 | 02:52 AM
Steve Grodin's Avatar
Steve Grodin
Try letting some air out of the tires.
Old Aug 12, 2001 | 06:57 PM
kostutsman's Avatar
kostutsman
I have had trouble with the mallet method - the clips tend to bend - It is usually easy to get the first clip on - after that I have used a screwdriver to get the inner spring on the inside of the outer ring then pop the ring on the rest of the way - do this for each ring --
ps do the clip closest to the ground first.
kos
To Trim ring install tips?
