Need tips on installing shroud
Old Feb 16, 2006 | 10:55 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Need tips on installing shroud
It's been a while since I've done this, but I cant get my plastic radiator shroud installed with the radiator up in place.
dont tell me I have to pull the radiator out again
would pulling the water pump be easier? should I jack up the car to get weight off the a arms?
Old Feb 17, 2006 | 11:08 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what year is the car? i can tell you how to do it on a 77
Old Feb 17, 2006 | 11:12 AM
mrvette's Avatar
mrvette
Corz, IMO reguardless of the year, I fount it SO much easier to cut the shroud on each side, horizontally to make a top and bottom 1/2, you will need pop the fan off at any rate, then it thing slides/hooks in place easy....to hold it back together, I put two tabs of aluminum bar on the lower 1/2 and slide the upper into place, all it does is hold it in line sufficient to function well.....
GENE
Old Feb 17, 2006 | 11:15 AM
icanfixitforyou's Avatar
icanfixitforyou
Just did this yesterday on my 79. If you have A/C remove the belt. Remove the fan and fan clutch assembly. Slide the shroud in, extra hands are helpful here, make sure you locate the bottom shroud tabs in the slots in the radiator support. Mind the radiator cooling fins. Reinstall fan/clutch and check for fan to shroud clearance. Hope that helps!
Old Feb 17, 2006 | 11:35 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Remove the body.
Old Feb 17, 2006 | 12:19 PM
GDaina's Avatar
GDaina
Originally Posted by Jughead
Remove the body.
that's one way to do it....another way is to install the shroud and rad as one unit, together.
Old Feb 17, 2006 | 01:33 PM
SteveG75's Avatar
SteveG75
The shroud is the number one reason that I installed electric fans. 10 minutes to pull the radiator and fans now.
Old Feb 17, 2006 | 03:28 PM
dmrodco's Avatar
dmrodco
if you dont want the HACK your expensive shroud you have to put the whole thing as an assembley I tried it wont work anyother way. I aint hacking up a 350 dollar shroud the PO did thats why I had to buy a new one
Old Feb 17, 2006 | 08:27 PM
Corz's Avatar
Corz
Remove the body.
damnit and I JUST put it back on
thanks for the tips guys
oh and, since a few of you asked, its a 69, its a cheapo old fugly plastic shroud, and ... no AC
hell, i dont even have pulleys on it right now
Old Feb 17, 2006 | 10:52 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
or put the shroud in first...
To Need tips on installing shroud
