Weiand Stealth
Old Feb 17, 2006 | 01:16 AM
Fubba's Avatar
Fubba
Default Weiand Stealth
Do you guys know if this manifold will fit under a 68-72 small block hood with an Edelbrock carb and drop base air cleaner?
Old Feb 17, 2006 | 08:41 AM
firstimer's Avatar
firstimer
Clears ok on my '73.
Old Feb 17, 2006 | 08:55 AM
SharkAttack's Avatar
SharkAttack
Yes, but 73 and later hoods have a raised center portion that provides for additional clearance.
Old Feb 20, 2006 | 03:19 PM
Fubba's Avatar
Fubba
Old Feb 20, 2006 | 04:07 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
It will clear.
Old Feb 20, 2006 | 05:08 PM
Fubba's Avatar
Fubba
Originally Posted by MEGALADON
It will clear.
Thanks, what I needed to know.
Old Feb 20, 2006 | 07:10 PM
Ganey's Avatar
Ganey
Not enough room under that hood for Stealth intake properly set up.
Would work on 73-79 med. rise hood.
Old Feb 20, 2006 | 07:22 PM
1972warship's Avatar
1972warship
The best I have done with my 72 small block hood is a performer EPS with 2.8 inch tall 14 inch diameter element. Of course this is with a drop base air filter assembly. I really would like a better intake but cannot see choking it with a smaller air filter. I believe that the smaller air filter will not flow enough especially being near the top of the carburetor. The best I can figure is that I would gain about 10 hp with an RPM or Stealth, but I would also probably loose it by choking it with a small filter..
Oh yeah, my engine is a 5200-5500 rpm 383 so it isn't really killing my engine. OK I say that to make myself feel better.
To Weiand Stealth
