Brake bleeding sequence 79
Old Aug 10, 2001 | 09:03 AM
GERALD's Avatar
GERALD
Default Brake bleeding sequence 79
One more time what is the proper brake bleeding sequence for my 79
Old Aug 10, 2001 | 09:07 AM
flynhi's Avatar
flynhi
Default Re: Brake bleeding sequence 79 (GERALD)
I think you work from farthest away to nearest to Master Cylinder. So RR, LR, RF, LF.
Old Aug 10, 2001 | 09:17 AM
Mack's Avatar
Mack
My manual says L.R.I.S, L.R.O.S, R.R.I.S, R.R.O.S, L.F, R.F. That's exactly opposite from the way I learned to do it, but it works on my car, so I do it in that sequence.
Old Aug 10, 2001 | 09:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I bleed brakes beginning with the farthest from the master cylinder. On Corvettes, the inner rear caliper halves have to be beld before the outers. The order I use is:
right rear inner,
right rear outer,
left rear inner,
left rear outer.
Front calipers only have one bleeder.
right front,
left front.
I've never had a problem using this order for bleeding..
Old Aug 10, 2001 | 09:35 AM
GERALD's Avatar
GERALD
Default Re: Brake bleeding sequence 79 (Mack76)
My Haynes repair manual also starts at Left rear inner,Left rear outer,but on the forum I see it starting with right rear inner right rear outer. I rebuilt my front calipers and replaced pads bleeded right front first than left full brake pedal now I want change all the brake fluid out now on the rear
Old Aug 10, 2001 | 12:08 PM
majglc's Avatar
majglc
I used the sequence outlined by Mack76 and Easy Mike when I replaced my calipers and flushed all the old fluid. It worked great.
Old Aug 12, 2001 | 11:46 AM
Bond007's Avatar
Bond007
Default Re: Brake bleeding sequence 79 (majglc)
I agree with Mack76 my GM manual also states LRIS/LROS/RRIS/RROS/LF/RF
and for what it is worth boys and girls GM did build our modes of transportation the last time I checked. :chevy
To Brake bleeding sequence 79
