DynoMax install question???
Old Feb 17, 2006 | 10:17 AM
kb2fzq's Avatar
kb2fzq
Default DynoMax install question???
Installed the Super Turbo's and made it work, but it's not right...the original mufflers have center inlets and center outlets connected to the 2 hangers on each side right in line...the DynoMax muffs are offset, left on one end right one the other end...the only way I could make it work is to have the outlet on the outer side of the body...about 4 or 5 inches from the stock hangers...well, as I said, a couple of universal hangers pulling up and away from the fenders and TA-DA...they're installed, but I just wish there was a better way....
Anybody got some advise??
Old Feb 17, 2006 | 10:56 AM
Ironcross's Avatar
Ironcross
You have the wrong set of mufflers. Walker has the center/center mufflers available, just go back and exchange them for the center/center. Better yet, they also have a direct replacement Dynomax for the vettes with hangers ect. with the tips attached also and ready to bolt on. Check out the Dynomax handbook at your local Walker supplier. Damn good set of mufflers, about the best you could buy.
Old Feb 17, 2006 | 11:01 AM
Ganey's Avatar
Ganey
Offset in (inside) & center out Turbos works well.
Old Feb 17, 2006 | 11:48 AM
kb2fzq's Avatar
kb2fzq
Too late to exchange anything...guess I should've asked the question before starting the project...now I'm looking for a way to make what I have work...these are Dynomax #17757, "supposed" to be direct bolt on....not from what I can see...
To DynoMax install question???
