Companion flange problem
Old Feb 16, 2006 | 08:28 PM
Desertvette's Avatar
Desertvette
Default Companion flange problem
I have a 67 vert with a "FA"rear end that has a companion flange about 3 1/2 " across. I'm in the process of putting in a new/used "OA" rear end ,out of a 76-77 vette with a companion or pinion flange about 4" across. The OA differential is suppose to be from a 76-77 rear end.
Does any one know if I can just swap these flanges or is there going to be a problem with the pinion splines being different. Am I going to have to replace the seal due to size or variation. The casting numbers on the cases are the same and this is the only difference I've noticed ,unfortunately ,after I installed the rear end in the car.
Also does anyone have a tricks for holding the flange and removing the nut without the factory tool.
Thanks Bob
Old Feb 16, 2006 | 08:36 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I am no help to you other than to tell you to send gtr1999 a pm and see if he can help you out. Or wait around and see if he will come across this thread. Gary is "The Diff Man"
Old Feb 16, 2006 | 08:52 PM
Desertvette
Thanks for the reply,Will wait for some help.
I know there has to be someone who knows what's up.
Thanks Bob
Old Feb 17, 2006 | 10:32 AM
GTR1999's Avatar
GTR1999
The differentials will fit,as you know the yoke needs to be replaced. The earlier 4 spd cars used a smalled U jointand yoke. The splines from the 2 should be the same, I think the 63-64 had a different spline. What you want to be careful with is not compressing the crush sleeve any more. If you have them both out of the car then you can check the drag on the bearings on them before the swap. You'll need a dial in/lb torque wrench with 0-30 scale. If you go to that post I ran on the differentials there should be more info and pictures to help. Not a big deal out of the car. Use #2 on the yoke spines too or it will leak.
Old Feb 17, 2006 | 12:27 PM
Desertvette
Ok GTR. Thanks for the reply.
I'll check the torque before ripping apart
Bob
To Companion flange problem
