Mechanical Tach/Electronic Tach Question
Old Feb 17, 2006 | 02:51 PM
69/03vette's Avatar
69/03vette
Default Mechanical Tach/Electronic Tach Question
Does anyone know if there is an electronic version to replace the mechanical tach in a 69 that looks stock. I'm thinking of upgraging to an all in one Mallory distributor, but I don't want to loose my tach in the dash.
Old Feb 17, 2006 | 04:29 PM
Ganey's Avatar
Ganey
75-77 are electronic & can use your faceplate to match.
Old Feb 17, 2006 | 09:24 PM
wombvette's Avatar
wombvette
I think that the 75+ will fit the cluster, but the face plate and colors will not be exactly the same. If you do use the face of the 69, the needle of the 75 will probably have to be used. It has a smaller shaft size as I remember. I did this with my 66. Had to modify and use the 75 needle.
Old Feb 17, 2006 | 10:30 PM
lowbuck72's Avatar
lowbuck72
Check some of my previous posts. You can convert yours yourself for about $25.
To Mechanical Tach/Electronic Tach Question
