I don't think so.....when the pressure reaches 7 lb., the cap will vent...Betcha....
That is the strange part. I do run a pressure gage on the system. I did run a 7 pound on the rad and another 7 pound on the pressure tank. I still ended up with 15 pounds of pressure in the system. I then run just a single 7 pound cap and no cap on the pressure tank and I had 8 pounds of pressure. I since run a 16 pound on the rad and a vented, drilled cap on the pressure tank and use it for an overflow.
Do any of you guys run a pressure gage?? Have you actually measured rad pressure??? Until you do don't assume anything.
I work in research and until you can varify anything don't believe it.
The only difference in my system as compared to the factory one is that I have a rad with a cap now instead of a closed one. How does this alter the way the system is pressurized???
Yellow - the way your system is set up should result in the exact same functioning as the factory (as far as I can tell from the pictures). The actual path of the coolant (for early C3s) was 1) fill through expansion tank, 2) enter system via heater lines 3) expand out top of radiator 4) cool and flow back to system via heater lines.
In a fluid system (ignoring gravity) the pressure on all sides of the system is identical. There is no "adding" of pressure caps. The lowest pressure cap will be the one that opens first. If there were ten 15# caps in various parts of the system and one 7# cap, the highest pressure the system could hold would be 7#. Of course, if your caps are non-functioning because of age or something else, they will open at an unpredictible time...
I think Norval is correct, the caps in series ADD together. In his case a 7lb cap on the rad will vent over 7 lbs, into the can which will vent over 7lbs. It will take 14lbs at the Rad to push 7 out of the can.
That is exactly what I found. Caps in series add up.
Nope. The laws of physics state that (assuming caps are identical and release precisely at 7 psi) the cap on the radiator and the cap on the overflow will open at exactly the same time. This assumes that the can is connected to the heater hose like from the factory, so it is at the identical pressure as the radiator.
Another scenario: The can is not connected to the heater hose and the can was just a sealed can with a cap of its own. If the radiator suddenly went to say 10lbs, the radiator cap would pop at 7, and the pressure between the radiator and the can would rise to 10 (almost immediately), at which time the cap on the can would also open since it is a 7lb cap also. Within a fraction of a second, with the cap open, the pressure in the system returns to atmospheric and both caps snap shut.
Edit: in reality, this second scenario might result in both caps cycling at a rapid rate as the pressure is repeatedly raised and lowered between the two tanks and two caps. You'd probably get a weird sound ratcheting, hammering noise from the caps.
They *don't* add...if you have tested some sort of serial cap scenario, your testing methods, cap settings or something else is just wrong.
Z man have you tried it?? Theory is great but sometimes you actually have to try it.
This is a pressure container hooked directly to the intake, it sees full engine pressure. I have connected it to another exactly the same container under the fender lip. I have tried all sorts of configurations, I had 4 different caps to play with and notice the pressure gage on the side of the tank.
It adds the total of 2 7 pound caps when they are in series.
Try it yourself. I have many times.
I then used a real pressure cap on the "pressurizer" cannister up near the fenderwell.
The gutted cap is nothing but a boundary for the coolant system now. Therefore my system works the same as the original radiator which did not have a filler/pressure cap.
I must be missing some info. How is everyone testing these?
Something like this? (assumes two 7# caps):
- pump up system until engine pressure is 7# above atm.
- cap on radiator or main system opens (right?)
- gas/liquid flows to overflow tank
- at this time, engine pressure goes back below 7 because some of the liquid escapes to the overflow and lowers the pressure (right?)
- keep pumping until pressure in both engine and overflow increase above atm (pressure in engine and pressure in overflow might be 4# over atm. but should be about the same because they are connected by a hose, right?)
- keep pumping until pressure on overflow causes cap to open (both engine and overflow tank are at 7#, right?)
- cap on over flow is rated at 7# and opens at 7#, right?? (If it doesn't open, then it's not a 7# cap.)
O.K. riddle me this guys......what's gunna' happen when I run a 27# cap on my radiator which I don't want to ever open (remember mine works just as the factory system except my radiator now has a cap) and a 13# on my expansion tank where I want pressure to escape if need be?
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well not sure but i bet your radiator will blow up before any fluid is released......i say this because the cap has to release in order to discharge fluid to your overflow tank....i'd say you should go the other way and run a 1-2lbs cap so it automaticdally opens up and let the overflow control pressure, on mine the discharge tube is blocked until the cap vents
i suspected that what Norval is stating would happen to a small degree due to the increased volume of the second tank but never thought it would be doubled
I'm not using the radiator overflow, check the pics. My system operates the same as the original....
I know this sounds strange and I have trouble believing it but I run a pressure gage on my cooling system and I found when I had two 7 pound caps in series like in the picture you ADD the two caps together. A pair of 7 pound caps gave me 14 or 15 pounds of pressure. Without a gage you don't relize that a pair of 16 pound caps are actually making the system operate at 32 pounds.
The caps do add up if in series.
Ok, I'll bite.
This would be true, only if you did NOT connect the bottom tubes to the heater hoses and no other hoses are connected to the tank.
So the "vent" tube from cap A goes directly to the tank with another cap (B) on it. Cap B vent port goes to the floor. Then total cap pressure is A + B. If the tank is connected to the heater hoses, then cap B can blow independantly and pressure would be B only.
Like You said, the cap overflow is not sealed - it is open to the atmosphere. Any overflow may dribble out of it, but it will never get drawn back in, right? In fact, if you hook the cap overflow up to the expansion tank, the entire radiator system will be operating in a non-pressurized manner which defeats the purpose of pressurized caps. Your coolant will boil at a lower temperature.
Yes
No
Maybe
Yes--- the cap is vented to atmosphere
No--- most pressure caps WILL allow suck back. If you run the non-pressurize vent hose into an empty pepsi (or Coke) can it will suck the coolant back into the radiator when it cools down. That's how the 73-82's work.
Maybe---Again, everything depends on what the surge tank is connected to. It has four total connections. Two heater (3/4) connections, and one 3/8" tubes. These are all pressure ports. Then you have the filler neck vent.
OK I'll try. A #7 cap releases when it has a #7 differential from inlet to outlet. By having a second cap the 2nd one will charge up to 7lbs. So now the 1st cap has 7lbs on its outlet so it will build 14lbs on its inlet to get to its 7 lb rating. So now you have 14lbs in the radiator and 7lbs on the 2nd tank.
