Radiator confusion...need some advice
So what do you think I should do? Are these two tanks working against each other? Should I get an aftermarket overflow tank?
I dont even need the heater hoses hooked up, i will disconnect them soon.
Thanks,
jim
i think i would use a pressure cap onthe radiator and have a vented cap on the overflow unit
edit maybe my suggestion wasn't clear i'm talking about venting the overflow cap
I guess I will have to get a aftermarket overflow container and use whats there. It does cool off nicely after you start moving.
I don't have it connected as you do. I have the hose from the radiator going to the bottom of the tank via reducers/connectors. I have the other bottom outlet of the tank blocked off with plumbing fittings. No heater hoses here.
I have the tank overflow outlet as the upper one near the cap and blocked off the other cap outlet.
Here's an old pic:
A common misconception is that there was some special engineering logic behind this and there wasn't. GM was in the mode of cutting costs and c/b radiators were much easier (and cheaper) to build.
It's not really that had to figure out which radiator is correct (originally installed by GM) for the car. A lot of catalogs call the aluminum radiator the "manual, No Air" radiator but that's not the whole story. The LT1 or L46 could be a manual w/o air and it's the 26" copper/brass unit.
Simple formula is the (no auto, no ac, no rpo) =aluminum with tank
If the car got any one of these, or any combo, then= copper/brass
Now, for your post. Looking at the picture on top I see a couple things. The aluminum radiator you have in the car is not right and someone did modify the core support, upper brackets, or both. The stock aluminum radiator you bought on ebay should have bolted right in. I suggest you buy a new core support and possibly an upper bracket and install 941b. Hook it up to the surge tank the right way and you'll only have one cap. Done!
I also noticed that the fan is sitting way too far inside the shroud and that could be the cooling problem you had in the first place. The fan should be positioned about half way in the shroud.
I see the double cap thing all the time and I just shake my head and wonder
The only thing that could be worse is when the tank is connected from the radiator cap overflow. That's the tube just under the cap. This connection is dead, no pressure, ever. It should go directly to the ground and nothing should ever come out of it. There are about ten different combinations of hooking up a double cap, depending on the heater hose connections, equalizer hose, and overflow connection. None of which I like.
This might be the only GOOD way to install the double cap system but I still don't see the reason for it. This radiator has end tanks on it and they have room for the fluid to expand and contract. So just fill the system about 2" from the top and forget it, that's what GM designed for the 26" c/b. If you really want that extra 2" of coolant, then fill the radiator up to the top, install a non-pressured plastic catch can and run the cap overflow into it. When the coolant expands out it will go into the catch can, when it cools down it will suck it back in. Nice job on the plumbing though
The expansion tank has to be used as such and not as a coolant recovery system...my setup functions just as the original...minus the heater.
The caps do add up if in series.
