Corvette Engine/ Transaxle
Old Feb 19, 2006 | 09:40 AM
jimmygmartin's Avatar
jimmygmartin
Default Corvette Engine/ Transaxle
Not entirely vette but some-what related. For years I've been wanting to build a formula style "kit" car. Chevy V8 mid mounted, where can I get a strong enough standard shift Transaxle without breaking the bank.
Old Feb 19, 2006 | 09:42 AM
84rzv500r's Avatar
84rzv500r
C5 corvette ? (brought to you by todays department of redundancy department)
Old Feb 19, 2006 | 10:04 AM
Cookwithvette's Avatar
Cookwithvette
What captain rude here is trying to say is that there was a thread here recently on that topic with a lot of information. Link to the post.
Old Feb 19, 2006 | 10:13 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Have you seen this:
http://www.factoryfive.com/table/ffr...TM/GTMkit.html
I think it uses a 911 transaxle
Old Feb 19, 2006 | 10:30 AM
84rzv500r's Avatar
84rzv500r
No, actually it was the C5 Corvette statement. Sorry if I came of as rude, not intended.
Old Feb 19, 2006 | 10:59 AM
jimmygmartin
I'm not sure you understand my question. I have no intension of using a corvette frame. It will be tubular, like a fomula car but a 2 seater, no doors, no roof, just a windshield, cage, seats, dash ,ect. Mid engine is when the engine is in front of the rear axle not behind it. If you can mount directly to a C5/6 trans-axle then it will do the job.
Old Feb 19, 2006 | 12:36 PM
70 LS1's Avatar
70 LS1
You can't use a Corvette transaxle, because it isn't really a transaxle. A normal transaxle for mid mounted engines has the outputs up near the engine with the trans part hanging off the rear. The Corvette version is basically a standard T56 trans bolted directly to the rearend. This would make the wheels way too far back for any car unless you were sitting on the engine.
Check ls1tech.com in the conversions section as there are some guys dealing with midmounted LS1's in Ultima's. Similar to what you are talking about.
Old Feb 19, 2006 | 12:38 PM
Cookwithvette
Sorry bro, I was out of line. Something else was bugging me and I think I misread what you said while grumpy... never a good combination. Anyhow sorry about that.
Old Feb 19, 2006 | 12:50 PM
SuprJames's Avatar
SuprJames
Originally Posted by BBShark
Have you seen this:
Probably your best bet. I think the Mosler MT900 uses the same one.
Old Feb 19, 2006 | 03:25 PM
stickboy's Avatar
stickboy
Most of the mid engine kit cars I have seen are using transaxles out of a Pantera or a 911. However I think the 911 tranny needs modified and is then run upside-down. Both cost pretty big money.
Old Feb 19, 2006 | 03:31 PM
84rzv500r's Avatar
84rzv500r
No Problem...
Old Feb 19, 2006 | 03:37 PM
84rzv500r's Avatar
84rzv500r
How about these guys...
http://www.kennedyeng.com/other.htm
Old Feb 19, 2006 | 04:41 PM
enkeivette's Avatar
enkeivette
I think I actually have an answer for you. There are several companies that sell sandrail transaxles for the LS1/ SBC bolt pattern. Most of them are four speed but they can take around 800hp. The axles come out the side and are on CV joints for IRS.
I've seen this in person opened up at sandrail expos, they look real stout.
Mendeola Transaxle
Old Feb 19, 2006 | 09:53 PM
jimmygmartin
Mendeola Transaxle
Cool!! this is what I'm looking for . Any idea how much??
Old Feb 19, 2006 | 10:32 PM
OldCorvetteKid's Avatar
OldCorvetteKid
If you're not doing any holeshots with a high H.P. motor, try an old Corvair transaxle...a cheaper way out, if thats important.
Old Feb 20, 2006 | 01:29 AM
enkeivette's Avatar
enkeivette
Don't remember exactly, several thousand for sure. Do a google search on sandrail transaxles.
Old Feb 20, 2006 | 02:53 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Mendeola Transaxle
damn! someone's on to me. *grrr*
To Corvette Engine/ Transaxle
Old Feb 20, 2006 | 05:12 PM
bb69's Avatar
bb69
Be real careful with the Mendeola ratings. They normally rate their transaxles for sand use, and for on road use. The on road HP ratings are much lower. There are a lot of transaxles out there; do some searches on kit cars. I believe Audi made one, the Porsche ones have been mentioned. Corvair boxes are heavy (cast iron) and never had as many options for ring and pinions. A VW bus trans is the strongest of the stock VW units, but it has to run upside down for a mid-engine. It's really going to depend on your HP level and how you drive it. Mendeola makes a 5 speed unit with overdrive, but the rated HP is a little low for the street.
Ken
Old Feb 20, 2006 | 05:15 PM
Twin_Turbo's Avatar
Twin_Turbo
porsche getrag boxes are very expensive
Old Feb 20, 2006 | 10:43 PM
84rzv500r's Avatar
84rzv500r
How about Eldorado/Toranado of the correct vintage
