Vacuum advance question ?
Old Feb 20, 2006 | 02:17 PM
Jim B.'s Avatar
Jim B.
Default Vacuum advance question ?
I have a 72 with a 350 base motor. It has the q-jet carb. The question is this, I seem to have no vacuum at the distributor . I noticed that there is a type of switching device, with two wires going to it. I do have vacuum going into it. What activates this switching device? And does it come in at a certain RPM for the proper advance?The mechanical advance seem to be working,But at about 3500 RPM it looses power, and starts to break up.Below this RPM it runs great.
Thanks for any input!!!!
Old Feb 20, 2006 | 02:23 PM
lars's Avatar
lars
The electrical switch is called a TCS for Transmission Controlled Spark. It only allows vacuum advance after the car is in 2nd gear or higher for reduced emissions (by retarding timing). You can bypass the switch and hook up directly to manifld vacum, but this will not cure your 3500rpm power loss - you have something else going on there that you need to correct.
Old Feb 20, 2006 | 02:34 PM
Jim B.'s Avatar
Jim B.
Thanks for solving the switch question.The car has been sitting for a while, do you think a carb rebuild might solve the problem?
Old Feb 20, 2006 | 03:34 PM
lars's Avatar
lars
"90% of all carb problems are ignition system problems."
-Lars-
To Vacuum advance question ?
