centerforce clutch
Old Feb 20, 2006 | 05:19 PM
harrin's Avatar
harrin
Default centerforce clutch
I had a 10 1/4 inch dual friction centerforce clutch, pressure plate and flywheel offered to me, I'm running a 71 454 with a mild cam, 10:1 compression and a M21, would this be a good match? Any advice would be appreciated.
Old Feb 20, 2006 | 05:29 PM
big_G's Avatar
big_G
Only if it's new...Don't forget to surface the flywheel if it is not already done.....
Old Feb 20, 2006 | 05:58 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It would likely hold a mild bigblock if it's a Dual Friction..
But.....
Is the flywheel for a externally balanced 454?
Is it the 168 tooth one so your starter will work?
If not you need to make sure your flywheel has both patterns. 10" ones have a small pattern and 11" ones have a large pattern. Unlikely you have a flywheel with both patterns and 454's used large ones.
Make sure of spline count. Older Muncies were 10 splines...later stuff went to 26 spline as did Richmonds, Nash's and Tremecs etc.
JIM
To centerforce clutch
