Radiator Rodding
Old Aug 10, 2001 | 08:47 PM
Bill W's Avatar
Bill W
Default Radiator Rodding
When a radiator is "rodded out", what actually is done?
Old Aug 10, 2001 | 08:57 PM
Rods77's Avatar
Rods77
Default Re: Radiator Rodding (Bill W)
I believe it's when they pull the radiator end caps off and push a rod down each core to clean them out, kinda like cleaning a gun barrel, then reattach the end caps..
Old Aug 11, 2001 | 12:00 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Radiator Rodding (Rods77)
Interesting. Do you know if there's a way to determine if a radiator is getting clogged and isn't flowing properly? I would think that a cool(er) spot on a section of the rad could be a sign, but if the flow is slow and not stopped, that would be hard to tell.
Old Aug 11, 2001 | 09:40 AM
GaryS's Avatar
GaryS
Biil W. I believe the description from the above post is accurate although I have never had to do it. If you can look into your radiator neck and see lots of white cr@p on the tubes and you have signs of early stages of overheating, your car may be a good candidate for this. Although my car doesn't overheat, the tubes have tons of this white silicate built up around them. This will be a winter project.
Gary
Old Aug 11, 2001 | 10:20 AM
Ganey's Avatar
Ganey
Default Re: Radiator Rodding (ddecart)
Rods77 description is accurate. The rod will go smoothly down the gun barrel. In the case of the rad., the rod has to be forced & you can expect some tubes to be completely blocked. 25+% blocked is not unusual. Needs to be done about every 10 yrs. or so.
:cheers:
To Radiator Rodding
