body alignmrnt 75 vert
Old Feb 22, 2006 | 09:58 AM
corvetteed2shark's Avatar
corvetteed2shark
Default body alignmrnt 75 vert
I am getting ready to put the body back on the frame for the final time after restoring everything and want to be sure the body & frame are correctly aligned any tricks on how to do this
Old Feb 22, 2006 | 12:22 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Did you remember to note how many shims were at each body mount? I think Corvettefaq has a page on body alignment.
Old Feb 22, 2006 | 03:37 PM
corvetteed2shark
counting the shims was easy not a one anywhere which I thought to be strange
Old Feb 22, 2006 | 09:01 PM
wills670's Avatar
wills670
There are alignment holes under the door sill plates. Remove the plates there will be plastic plugs under the plate and one hole on each side of the frame. Line the holes up and that should put it where it belongs.
To body alignmrnt 75 vert
