Heater vent
Old Aug 11, 2001 | 12:43 AM
82 Super Vette's Avatar
82 Super Vette
Default Heater vent
Drove the vete today and again it seemed to be hot inside with air blowing on my foot . I put my hand down by the heater floor vent while driving and there was hot air blowing from it. The air blows only while moving which would indicate that a door flap is not shuting but I am not sure of the proper way to repair it or if there may be another problem I am missing. There was recently a post on this subject and some members have experienced this problem themselves. Does anyone have any ideas where to start on this? :confused:
Thanks!!!
Old Aug 12, 2001 | 02:02 AM
79 vette's Avatar
79 vette
Default Re: Heater vent (82 Super Vette)
On my 79 the blower motor is always running cause there is no off switch.If u look at the switch that controls the fan speed and move it up so it is closest to the winshield on the side of the switch it will say HI but if u move the switch down furthest away from the winshield and look at the side of the switch it says LOW.What I do every summer is open the hood and with the key on u should be able to hear the blower motor running.There is a silver relay on the passanger side right next to the switch that sets off the alarm if the hood was open.There are 2 plugs connected to this relay.The top plug has 2 wires and the bottom plug I believe has 3 wires.With the ignition key on and the blower motor on if u disconnect the top plug from the relay the blower motor should turn off.Let me know how u make out
Old Aug 12, 2001 | 02:27 AM
82 Super Vette
Default Re: Heater vent (79 vette)
I don't believe the heater motor is blowing due to no air while sitting still. The air blows only while in motion driving and seems to be free flowing air through the floor heater vent at that time. I do believe there is a heater vent flap not closing or opening etc. Do you have any other ideas?
Thanks!!!
Old Aug 12, 2001 | 07:32 AM
terry82's Avatar
terry82
it does sound like you have a door open,check vacume lines but i also would install a coolant line shut off valve.the factory valve does not shut off all the way.put a valve shut off between motor and factory valve shut off ,heat wll go away
Old Aug 13, 2001 | 01:12 AM
82 Super Vette
Default Re: Heater vent (terry82)
terry82, Are you refering to a manual heater hose line shut off? I have always been under the impression that if the coolant does not circulate through the heater core it would rot out. Have you had any experience with this happening?
Thanks!!!
Old Aug 14, 2001 | 12:41 AM
82 Super Vette
Anyone know the answer to this? :yesnod:
Thanks!!!
Old Aug 14, 2001 | 10:37 AM
terry82's Avatar
terry82
i have had manual valve on for over 2 years .i open back up in sept close back off in may. got the idea from net vette or cross-fire .no problems yet
To Heater vent
