vacuum hose kits?
Old Feb 22, 2006 | 11:44 PM
79 Bullet's Avatar
79 Bullet
Default vacuum hose kits?
I had read about some vacuum hose suppliers were better than others mainly because they provided the proper thickness of the rubber tubing that resulted in better fitting. However I can't find any info on this on here after doing a search.
Who do you guys recommend?
I tried to check out DR. Rebuid's web site but it looks like some legal dispute is going on with them and ZIP.
Old Feb 23, 2006 | 07:58 AM
markdtn's Avatar
markdtn
Dr Rebuilds stuff is very good. It will be as close as possible to correct and have a good diagram to boot.
Old Feb 23, 2006 | 07:59 AM
lvrpool32's Avatar
lvrpool32
I've done 4 or 5 vacuum kits...Dr Rebuild's where the best
Nick
Old Feb 23, 2006 | 09:41 AM
JIMS1970VETTE's Avatar
JIMS1970VETTE
I did one of mine with Dr Rebuild and it came out great, and I am going to do my other car also, good instructions and straight forward. It helps when installing these hoses to apply a little Vaseline when pulling hoses through rubber grommets also. If you do order from Dr Rebuild get the laminated vacuum diagram for your year, nice reference tool.
Old Feb 23, 2006 | 09:47 AM
TedH's Avatar
TedH
Dr Rebuild is #1 in my book for ALL Vacuum hose systems (I replaced them all on my '80 and all from Dr Rebuild). Performance (idle, off idle and WOT) smoothed considerably after I replaced the rotted/cracked/broken vacuum components that were original to my L48. Those plastic vacuum connectors DO degrade and the stuff from the parts stores are a very cheap imitation (not viable IMOO).
Dr Rebuild:
http://www.docrebuild.com/dr-r-web/aaa-home.html
Old Feb 23, 2006 | 11:47 AM
CGGorman's Avatar
CGGorman
Don't worry about that stuff with Zip. It's a grudge he's holding. Been going on for years. Just order the Dr.'s kit and know it'll be right.
In fact, everything I've ordered ($2-3000 worth) from the good Doctor has been top-flight.
Old Feb 23, 2006 | 01:12 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Hoses and radiator seal kit from the Doc. He's my first choice on OEM and repro items.
Old Feb 23, 2006 | 02:27 PM
icanfixitforyou's Avatar
icanfixitforyou
Got mine from the Doc and all was well.
Old Feb 24, 2006 | 05:12 PM
79 Bullet's Avatar
79 Bullet
As always thanks for your replies!
To vacuum hose kits?
