No gears
After getting stranded last week due to a points issue, I decided to get the Crane XR-i electronic points replacement. Aside from the fact that the hex screws that came with the kit did not fit any hex (standard or metric) that I could find in the auto store, the install went pretty well.
Started the car and the idle was really high and I couldnt get it to kick down. Decided to take it around the block to warm it up. Everything was fine.
Brought it home.
Lowered the idle setting.
Set the timing.
Buttoned everything up.
Got in the car to take her for a spin and I couldnt put it in gear. The shifter is stuck in the neutral area between 1st and 2nd. I can move the shifter to R, but that doesnt actually put it in gear (4sp, by the way).
If I let out on the clutch, the car does not move, but dies as if it is being bogged down.
Had the clutch, 4sp oil, pinion seal replaced 2 weeks ago.
2 questions:
1) Any idea what this problem is?
2) Why does my car hate me so much?
I am going to have a few beers and cry.
My tranny would hang up....when I made this adjustment, all was and still is well.
Thanks for the help. I may keep her after all...
Sorry to be a pain about this and I am sure it will make more sense when I get under the car.
Thanks again for the help.
Seriously, it is not a very difficult procedure.
you lock the shifter arms with the drill bit inserted in the hole, the transmission arms are in neutral, next adjust the linkeage so that it fits into the transmission arms....
As I said above, once you get under the car and look, it will be obvious what you have to do.
Good luck.
Thanks for walking me through it. This car has caused me to go through a self taught (and forum guided) crash course in auto mechanics.
Sounds like you are new to corvettes? if so welcome you'll either love or hate them in short order. Keep in mind these car weren't a practical car even when new. The wiper and headlight systems never worked that good, they leak rain inside, the windshield metal and frame rots,there's no room, they eat gas, etc, etc ,etc. I've had most of the problems with them over the past 30 years, still have them. Cursing, punching kicking, even walking across them and still I work on them. Learn to walk away from it or sell it, otherwise you'll go crazy and or broke very quickly. Don't get caught up in all the new fangled hot rod parts on the market if you only want a street car. The stock setups in most cases work the best. BTW, I missed the points problem, but I use them over any of the aftermarket systems in my cars. I love points and haven't been stranded by them yet.
Good luck and don't give up yet. Also see if there is a vette club in your area to help you. I ran technical classes the past few years on just type of thing.
Thanks for the welcome. I entered the world of vette ownership in early December. I previously had a 72 Nova, which I loved, but there was so much I wanted to change (engine, disc brakes, manual trans, convert) I figured I might as well get a car that had all those things to start off with. Started reserching and fell in love with the specifics of the early C3s. When I found one in my price range, I jumped on it. I can tell the guy I bought it from was not mechanically inclined (he took it to the shop to have a rubber gas line replaced) and he rarely drove it. So, I have been going through the process of getting it back into shape as it is my daily driver. It has been one problem after another, but I keep hoping I will get to the point in which I am not worrying about it stranding me.
The vette club is a really good idea. Might look into that.
Thanks again!
