Wheel Stud Upgrades
Old Apr 10, 2006 | 07:55 AM
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by Batsy74
this is a copy of that post
I wanted to upgrade my wheel studs from 7/16 to ½ inch and I didn’t want to remove the spindles from the car. I was using a stud from Morosso with a .615 knurl and the stock stud holes need to be drilled out.
With a hand drill there is no way of keeping the new holes square with the flange so I made a fixture .
It was made from a piece of 1 inch diameter by about 3 inch long round stock and a piece of 1 ½ by ¼ inch by 3 inch flat stock. The 2 pieces are welded together.
After welding the two pieces are put in a lathe and the hole is drilled in the round and flat stock and then the flat stock is faced off to the hole and bottom of the fixture is at right angles to each other.
A locater pin is also required so the fixture can be accurately place over the hole.
For a locater I turned a piece of ¾ inch round stock down to fit inside the fixture and a smaller end that fits in the existing hole in the spindle after the stud is punched out.
I do NOT run dust shields. On the rear on the drivers side at the 9 oclock position a stud can be driven out, the fixture clamped over the hole with a pair of c clamps, a hand drill used the drill the new hole and a full 3 inch long x ½ inch morosso stud installed. There is room without the dust shield.
ON the passengers side it is at 3 oclock.
If the stud has a .615 knurl and that is common you have a choice of a 19/32 drill or .594 diameter hole or a 39/64th or .609 hole. I would try the .594 hole first and see if a stud would pull in. If not go for the 39/64 hole and a .006 press fit.
I don’t remember which I used since I have all the drills in the shop and don’t remember which I used.
Place the locater pin in the fixture, insert the small end of the locater in the existing hole and using clamps secure the fixture to the hub, remove the locater and drill with a hand drill.
Both of the above drill bits will work.
Good luck
This is a picture of the fixture
Old Apr 10, 2006 | 07:59 AM
norvalwilhelm
You knock the old stud out, put the pin in the fixture and put that in the old hole. With a pair of vise grips hold the fixture to the hub and drill away. The fixture holds the exact center and at the same time holds the drill bit square to the flange.
You can not just use a hand drill and no fixture. The hole will wonder off square.
I also don't believe in lug nuts that are only threaded part way. I use nothing but completely threaded all the way through lug nuts. They have twice the amount of holding thread and no chance of the head snapping off.
My studs are 1/2 x 3 inches long and the end of the studs passes all the way through and completely threaded stud.
I torque to 85 foot pounds,
Old Apr 10, 2006 | 11:01 AM
Twin_Turbo's Avatar
Twin_Turbo
Originally Posted by turtlevette
Sounds like too much trouble and a lot of risk to mess it up. If things are off just a few thousands you could have fitment problems. If not using hub centric wheels you will have an uncorrectable out of round situation.
What about high strengh studs that are direct replacement? Does ARP have anything less than a .480 knurl?
it's absolutely fool proof, even you can do it
You hammer out the old stud, then you tap the guide pin into the hole, it's a tight fit. Then you slide the fixture over it, clamp it doen and then remove the guide pin. That way the fixture is eprfectly centered and the fixture tiself is perfectly perpendicular because the base was machined in a lathe. Drill out the old hole, remove the fixture and install the stud. There's no way the stud position will change.
it's just as easy as slip fitting wheel bearings
Old Apr 10, 2006 | 12:05 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Oh hell, you've done it now! *ducks*
Old Apr 10, 2006 | 12:32 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I don't know about that. I can't seem to get a tap in straight. You wouldn't believe the things i've messed up. On second thought YOU would. I guess i'll never be able to impress the almighty corvette god of the Netherlands. The only time i've snapped a stud is when i ran some 3/16 non hub centric wheel spacers. I would recommend high strength 1/2" studs for anyone running wheel spacers or adapters.
Old Apr 10, 2006 | 12:36 PM
Batsy74's Avatar
Batsy74
I thought I was going to need to run spacers. But I am not. I still like the 1/2 inch studs... Potholes in NH are killer!!!
Old Apr 10, 2006 | 12:43 PM
Twin_Turbo's Avatar
Twin_Turbo
Dude, I was just making a little fun man. The fixture aligns your drill, how can you mess that up?
Old Apr 10, 2006 | 03:38 PM
turtlevette
I'd find a way. So nobody makes high strength direct replacements.
Making fun? Yes i know, me too. But i am serious about you being the corvette god of the east! I have a pretty hard shell and think its funny trading jabs. You won't upset me but i do realize i **** you off sometimes
Old Apr 10, 2006 | 03:58 PM
Twin_Turbo's Avatar
Twin_Turbo
no, why would you want to stick with those short 7/16 studs. There's a reason why all C4s have 1/2" studs.
Oh yes, I can have a pretty short fuse LOL but you have the tact of a moab sometimes
When it comes to Corvettes here I'm pretty much a loner, I don't mingle a lot w/ other corvette owners..I like to keep to myself. Only a handful of people have seen the stuff I'm workig on IRL. I value my privacy. I enjoy tinkering all by myself without being disturbed
Old Apr 11, 2006 | 09:03 AM
norvalwilhelm
I worked basically alone for more then 10 years then I met Brain and Doug at a cruise night and since we all loved the same hobby, spent alot more money then we should on our cars we started working and going to shows together and it is ALOT more fun sharing.
While I still like to tinker alone in the shop I look forward to the times when the guys come over and we tinker together.
Old Apr 11, 2006 | 09:17 AM
Twin_Turbo's Avatar
Twin_Turbo
Oh, I met a bunch of people but most corvette people here aren't into mods, DIY or things like that. I enjoy the racer crowd much more, there's people building all kinds of cool drag cars and hot rods ...just not corvette people.
I'm sure tinkering in your shop is fun
Old Apr 17, 2006 | 03:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Norval, you want to sell one of those jigs?
Old Apr 17, 2006 | 03:26 PM
  #33
Twin_Turbo's Avatar
Twin_Turbo
I have one...how much money do you have
Old Apr 17, 2006 | 03:53 PM
  #34
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
so, is this handy, dandy tool rentable????
Old Apr 17, 2006 | 04:56 PM
  #35
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I don't want to even think about the shipping charge. Some guy in Spain bought a Fjord AA jack from me one time...
Old Apr 17, 2006 | 05:27 PM
  #36
Twin_Turbo's Avatar
Twin_Turbo
Ít shouldn't cost that much, only a small box..maybe 10$ or so. Shipping isn't that bad.
Old Apr 17, 2006 | 05:59 PM
  #37
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Umm...how much are we talking for the jig?
To Wheel Stud Upgrades
Old Apr 17, 2006 | 06:04 PM
  #38
Twin_Turbo's Avatar
Twin_Turbo
it's an original & rare NorvWilTool .. I know of only 2 in existence where batsy owns #2 but I have the original #1 .....let's say 500$ for the drill, guide & fixture
Old Apr 17, 2006 | 07:31 PM
  #39
Batsy74's Avatar
Batsy74
I'll sell mine for $10... Shipping is $490 anywhere in the world.
Old Apr 17, 2006 | 07:36 PM
  #40
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
