My Moroso studs came in today from Summit. These things are freakishly long, and I'm afraid that they won't fit under the caps for my aluminum AR wheels. Can I safely cut them down? My 19/32 drill bit will be in tomorrow. Bloody expensive thing...
What is bloody expensive? The drill bit or the studs.
I used 3 inch long studs and nuts taped all the way through. If you cut a stock nut is half you will find it is really not a great design.
Nuts that are taped all the way through are far far strong and to me alot safer. The thead should pass all the way through the nut.
Don't cut them and willout the backing plate on it is easy to drill and remove and install the new studs on the car. If the backing plate is still on you will have to trim it in the 9 oclock position on the drivers side and 3 on the passengers side.
It is NOT difficult to upgrade to 1/2 by 3 studs. Do not cut anything.
The drill bit. I had to order it through the local Grainger outlet.
Once I have bit in hand, I'll see how the studs fit with my wheels. I'm still afraid that I'm going to have to shorten them a bit. The 3" studs are a LOT longer than the stockers.
Post pics of the wheels you are going to be using with the new studs.
Any of you guys have an idea of where I can get a good steel-drilling 19/32" bit with a 1/2" shank? The one Grainger sold me has to go back - it's a straight-shank bit, and won't fit in any drill I have. Arrgh...
"I don't know what you have available but here we have CN Weber a large supply house and you can buy any apprentice drill bit up to 1 inch for about $8.00
You will have to check around with a machine supply shop
Norval"
Did you explain the problem to Grainger and see if the had one that would work?
The studs need to fit under the wheel caps. I personally don't see a reason why you couldn,t shorten the studs... but I would wait for a response from the resident forum experts... (Perhaps start a new thread to get some attention to the subject, because I find the older threads get looked over.)
The bit I got was the only one Grainger listed in that size. It's going back on Monday. I found a machine shop supply store with an eBay store that had 1/2" shank 19/32" cobalt drill bits, both USA made and import. I ordered one of each. Total for those two bits with shipping was less than the one Grainger bit.
OK, drill bits are here, but I probably won't get to mess with this until early next week...but I thought of another question. What size drill bit do you need to use on the stud openings in the brake rotors? 1/2"?
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
True cobalt bits will go thru anything, best bits you can buy. I have a question though, are you snapping off wheel studs or running slicks and worried about breaking studs ? THere are many things on my Vette I would beef up before wheel studs
I'm running lug-centric AR wheels. It's one of those "while everything is in pieces" things. I'd rather upgrade them and be done with it. Having some of the stock studs out now, it's frightening to see how small they are.
no, why would you want to stick with those short 7/16 studs. There's a reason why all C4s have 1/2" studs.
Oh yes, I can have a pretty short fuse LOL but you have the tact of a moab sometimes
When it comes to Corvettes here I'm pretty much a loner, I don't mingle a lot w/ other corvette owners..I like to keep to myself. Only a handful of people have seen the stuff I'm workig on IRL. I value my privacy. I enjoy tinkering all by myself without being disturbed
Interesting comment there TT, I"m pretty much the same way,....sorta used to being the boss when helping friends also...guess it's my nature....so it's only seldom someone asks my help...oh well....
comes to tech decisions it's usually me that figgers it out....sometimes at great consternation too....
They are call prentice drills which means they all have a 1/2 inch shank. I actually bought every one. I start at say 1/64 and go right up to 1 1/4 inch in steps of 64ths. Most are under $10 CDN and even an 1 1/2 drill bit has the 1/2 inch shank.
I would use the 19/32 bit... let the longer knurls help hold the rotors on.
I'm afraid that the 19/32 would be too loose around the threaded part of the stud. The knurls are going to end right at the hub surface. Maybe I'll try a bit that's a hair under 1/2" and go from there.
