Headlight vacumcanister
Old Jun 16, 2006 | 06:01 PM
hebbe's Avatar
hebbe
Default Headlight vacumcanister
Hello ! I drive a -82 CE
Why does the rubber cover in front of the stearingside headlight vacum canisters get sucked down to almost nothing and leave the headlight down ? I hear a cleare wispering sound of air around it and when I put my finger on it, at a spot that I supose is a hole in the rubber, then the headlight raises normaly. But the rubber remains sucked in almost wanting to disapear backwords into the canister. I have had a mecanic change the rubbercover but the same problem apeared after a few months. The passanger side headlight is working fine and that cover is normal and in normal shape and normal preasure with air in it and no wispering. What is the problem ? The rubbercover alone or something else ? Can someone please explain how this works so I perhaps can have the chance of saving some dear money
Thanks a million for any answer !
hebbe/Peter
Old Jun 16, 2006 | 11:22 PM
Jack71's Avatar
Jack71
Are you talking about the vacuum actuator in front of the headlight that you can see when the hood is up? If so, you may consider installing a new actuator rather than replacing the rubber boot.
There are lots of headlight/vacuum articles at www.corvettefaq.com
Old Jun 17, 2006 | 02:41 AM
hebbe's Avatar
hebbe
Thanks ! Yes the rubber boot is located in front of the vacuum actuator protecting the arm pushing up the headlight. Why should this leak on the rubber boot indicate need of replacing the actuator ?
Thanks for the adress ! I´m sorry but I couldn´t find any article describing the actuators function in small detail !
hebbe/Peter
Old Jun 17, 2006 | 02:12 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I believe Ecklers sells a repair kit ... comes with a couple of boots and seals to fix your issue. Did mine years ago, and it fixed them without having to replace the whole things.
Old Jun 18, 2006 | 02:38 AM
hebbe's Avatar
hebbe
Found this very informative link myself as I searched further into this fantastic deep, without bottom, forum. Thanks again all you interrested in answering my questions. Perhaps you and others can find comfort in the link !? hebbe/Peter
http://www.corvettemagazine.com/2002...s/lights-1.asp
To Headlight vacumcanister
