pinion nut torque on 80 differential?
Old Aug 12, 2001 | 03:20 AM
lou's Avatar
lou
Default pinion nut torque on 80 differential?
I know the preload torque on the pinion bearing is 12 to 15 inch pounds, but what is the actual torque on the nut itself. I have read that it is 250 foot pounds. Can this be right? :confused: I need some help if anybody knows, I would really apreciate it. lou
Old Aug 12, 2001 | 01:58 PM
dually4wd's Avatar
dually4wd
Default Re: pinion nut torque on 80 differential? (lou)
It takes a whole lot of torque to get a new crush sleeve started. Big cheater bar, (at least 250 ft pounds). Once it starts to crush, it drops to maybe 150-200. If you remove the pinion later to replace the seal, be carefull not to pull it tighter and over-preload the bearing. Maybe 60-75 ft pounds with loc-tight?
