Tell me this is no major problem?
Old Aug 12, 2001 | 05:00 AM
8T1-7T9 BIONIC VETTE's Avatar
Default Tell me this is no major problem?
A friend of mine was over tonight, and looking at my engine, he noticed the vacuum port at the rear of my Edelbrock 750 carb is hooked up to my PVC on the valve covers, and the vacuum port at the front of the carb is hooked to the reserve vacuum canister. He claims this is backward and the PVC should hook up to the front port, and the reserve tank should be at the rear port. Does this have any affect on performance or operation of the engine? If so, let me know, and I will switch tomorrow, and post results. :confused:
Old Aug 12, 2001 | 05:34 AM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Tell me this is no major problem? (8T1-7T9 BIONIC VETTE)
It doesn't really matter.
AC
bluevette's Avatar
bluevette
Mine is the other way as your friend stated. Don't know if it makes a difference or not, I'm no expert.
John
Old Aug 12, 2001 | 08:54 AM
killain's Avatar
killain
Oldtimer
Not really a big problem, they are suppose to go the other way around, brake booster off the back, I think of any problem it could cause? :crazy:
Old Aug 12, 2001 | 09:03 AM
Dalannex's Avatar
Dalannex
"This is no major problem". There, how's that make you feel? I think they are supposed to be the other way around, but don't really know if it'll make any difference or not.
Old Aug 12, 2001 | 09:26 AM
Bubba65's Avatar
Bubba65
Default I's no problem
Both the manifold port behind the carb and the port in front at the base of the carb are exposed to full manifold vacuum at all times. Put a vacuum guage on each one. You'll get the same reading. Both of them should be about the same size. Therefore, it doesn't matter which system you plug into either one. Only the NCRS folks would want the routing done the same way as the General did; but, you have an Edelbrock carb, routing shouldn't matter to you. Route those hoses so they are clean, neat, & look good to you.
Old Aug 12, 2001 | 09:29 AM
Red73's Avatar
Red73
Default Re: Tell me this is no major problem? (Dalannex)
Cappy, I had the brake booster on the rear and the PCV off the front. I'm not sure that it really matters. Rod :cheers:
[Modified by Red73, 7:55 AM 8/12/2001]
Old Aug 12, 2001 | 02:48 PM
Default Re: Tell me this is no major problem? (Red73)
Thank you friends,
Since it only affects appearance.....I'll change it back later.....Today I'm going cruising.....I'll post later, when I do make the change, and let you all know if the switch made some sort of noticeable difference. :seeya: That Red73 car has a carburator on it just like the one I have on mine......only mine wears sun glasses and smiles alot.... :D
Old Aug 12, 2001 | 04:41 PM
Red73's Avatar
Red73
Cappy, Are you in the 12 second range yet? Rod :cheers:
Old Aug 12, 2001 | 05:31 PM
Rod,
Still working on it......I just received The RAM AIR BOX system and will be hooking it up to the Turbo Ducts on the hood.....I'm using the 14"X 3" 80 degree with drop base.....Having some difficulty getting the duct to line up with the Intakes on the hood.....almost there one of the ducts touches the A/C Compressor clutch and rubs when A/C is turned on.....minor adjustments to the hose duct should resolve this glich......will keep you posted on how this system improves the performance.....I also received the BFG Drag Radials from tire rack and have not mounted yet to rims.....so it's a work in progress....Low 12's or high 11's will make me a Happy Cappy
To Tell me this is no major problem?
