shimming power steering pump bracket
Old Feb 28, 2006 | 07:58 PM
gator79's Avatar
gator79
Default shimming power steering pump bracket
it looks like my power steering pump on my 1971 454 big block will have to be shimmed out from the block. my crankshaft pulley has 3 grooves and if I bolt the pump bracket directly to the block it is not far enough back to line up with the groove closest to the crank. so it will have to be shimmed to line up with the second groove from the crankshaft. is this normal? the car has factory a/c but the compressor was not on the car. I assume the groove closest to the crank is for the a/c. it just seems a little mickey mouse to start shimming out brackets.
