electric fans...
Old Mar 1, 2006 | 09:25 PM
jerrylee's Avatar
jerrylee
Default electric fans...
hey guys..i'm having mixed reviews on wich way to hook up my fans...but one guy told me that he bypassed all the relays n sensors n has it hooked up to a toggle switch in the cockpit n he only puts the fans on while city driving...on the parkway he keeps them off......is this a good idea.....would realy appreciate your help......thanx...
Old Mar 1, 2006 | 09:26 PM
Brettmc's Avatar
Brettmc
Might be a bad idea. You could get into trouble if you don't watch the temp gauge....
Brett
Old Mar 1, 2006 | 09:39 PM
wnmech's Avatar
wnmech
I agree with brett about possible getting in troubl by forgetting to turn on the fan switch. I bought a kit at autozone to turn on my electric fan it cost around $20 dollars and is real easy to hook up it has a temp sensor that attaches thru your radiator and just a few wires thru a fenderwell mounted relay to turn the fan on.
Old Mar 1, 2006 | 09:59 PM
jerrylee's Avatar
jerrylee
Default fans..
thanx guys.....i have a big block so i realy don't need any cooling trouble........n brett isn't jackson the home of walter payton.....
Old Mar 1, 2006 | 10:01 PM
chris75stingray's Avatar
chris75stingray
thats how mine is hooked up. i only turn it on in traffic
Old Mar 1, 2006 | 10:05 PM
jerrylee's Avatar
jerrylee
how long have u had that set-up n have u had any problems...
Old Mar 1, 2006 | 10:17 PM
ZL1powr's Avatar
ZL1powr
Pretty easy to hook up with a relay and temp sensor and then you don't have to worry about forgetting to flip the switch.
Old Mar 1, 2006 | 10:22 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
How could we possibly answer that? Only you know your ability to watch (baby-sit) the temp gauge.
Old Mar 1, 2006 | 10:31 PM
Brettmc's Avatar
Brettmc
I know Walter went to school here at Jackson State. That's a good trivia question: What is Walter Peyton's hometown?
Brett
Old Mar 1, 2006 | 10:50 PM
Richard454's Avatar
Richard454
Default Switch & Relay
If you are going to hard wire the fans-DO NOT just run the switch for power. Every switch I have seen will NOT handle the current for the fan(s) and a relay is needed. I have seen switches catch on fire! Use the switch JUST to trigger the relay.
If you need a wiring diagram I can e-mail you one.
Richard
Old Mar 1, 2006 | 10:57 PM
Warhead's Avatar
Warhead
Try this
http://www.speedspecialty.com/store/...uct=mfanswitch
I had this on my 97 Z28. You can manually override fan control either high or low speed. With switch off the computer still controlls fans.
Edit
Never mind, thought you had an LT1 engine.
Old Mar 1, 2006 | 11:13 PM
jerrylee's Avatar
jerrylee
Default sweetness...
Brett
as far as i know he was born n raised in columbia.....
Old Mar 1, 2006 | 11:47 PM
Richard454's Avatar
Richard454
Default Here's how
I had a couple people ask for the diagram....
To electric fans...
