Steering gear grease?
Old Mar 2, 2006 | 10:16 PM
VETTEVIC's Avatar
VETTEVIC
Default Steering gear grease?
Can a high quality synthetic grease like mobil 1 be used in a steering gear rebuild instead of the usual steering gear lube? im looking for something that doesnt break down so much. Mine looks more like cinnamon paste when I took it apart for rebuild.
vic
Old Mar 2, 2006 | 10:56 PM
goinbroke's Avatar
goinbroke
Gary (gtr1999) is the steering box guy here. I'm almost certain he uses M1 synthetic grease when he does his rebuilds. Maybe check with him to be sure....... or wait till he replies.
Old Mar 3, 2006 | 08:59 AM
GTR1999's Avatar
GTR1999
I use Mobil 1 synthetic grease.
I just answered this question on C2 this might help,
http://forums.corvetteforum.com/show...541&forum_id=4
Old Mar 3, 2006 | 01:15 PM
Jim Shea's Avatar
Jim Shea
I just added this information regarding manual gear lubrication on the C2 board.
FYI, the actual Saginaw engineering drawing for the Corvette manual gears says the following: "Lubricate gear with 11 oz lubricant per SSG spec 5695023 thru side cover bolt..."
Of course they are starting with a newly manufactured, bone dry gear, so 11 oz is sufficient to lubricate properly and leave some air space inside the gear for the grease to expand with underhood temperatures.
I am not sure what grease is specified by the old 5695023 spec. The last word that I was given by engineers at Saginaw was to use a good grade of lithium based chassis (ball joint) grease.
Saginaw stopped manufacturing manual gears with the introduction of the C4 Corvette which used rack and pinion steering in 1984. (They actually sold the manual gear business along with the manufacturing equipment.) Lubricants (and greases) have changed and improved in the last 22 years.
Jim
To Steering gear grease?
