Difference between rear springs?
Old Mar 2, 2006 | 11:33 PM
ltlevil's Avatar
ltlevil
Default Difference between rear springs?
What is the difference between rear springs between 63-79 and 80-82 rear springs? I know one is 2-1/2" wide and one is 2-1/4" wide but are there any other reasons they are not interchangeable? Also I realize (think) the 80-82 springs are fibreglass.
Thanks,
ltlevil
Old Mar 2, 2006 | 11:59 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
63-78 used 2 1/4" wide spring. I think most in 78 and on through 82 the switch was made to 2 1/2" wide springs. All FE7(gymkhana) springs are 2 1/4" wide necessitating the use of shims front and rear at the mounting point on years with the 2 1/2" carrier. 81/82 automatics with standard suspensions used the fiberglass spring. 81s with FE7 or 4 speeds used the steel springs. 82s with FE7 used steel, also.
