Boy am I dumb
Old Mar 3, 2006 | 01:50 PM
collectskulls's Avatar
collectskulls
Default Boy am I dumb
Hopefully someone can solve this for me.
Put tranny in and was screwing with the clutch stuff,
and guess whats missing off my 400 block.
The hole to screw in the pivot ball or what ever you want to call it.
Am hoping someone has had to do this and give me some
great advice.
Old Mar 3, 2006 | 01:57 PM
big_G's Avatar
big_G
great advice.
you need this...It says it's for a bb, but I think it will work.
http://www.sdpc2000.com/catalog/1006...-Corvettes.htm
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
great advice.
OUCH, that is not good news,
is there a boss there that you can drill and tap?
Old Mar 3, 2006 | 02:01 PM
redvetracr's Avatar
redvetracr
I just went through this, my new race motor was built from a "lightened" Dart little M and sure enough someone lightened the boss for the stud right off...You have (maybe) two choices, either drill and tap the block (I would have if I could have) or go to Scroggins-Dickey and buy a bolt on bracket...my bracket unfortunately took some screwing around with as it was bent wrong and by the time I had it rebent the way I wanted it there was no room for a nut on the back side of the ball stud so my ball stud got tig welded in...so far so good though!!
...redvetracr
Old Mar 3, 2006 | 03:34 PM
collectskulls
Thanks guys
I am gonna stew this over for a few days as taking a
drill to the motor makes me
Mind you so did tearing the car apart before i started
Old Mar 3, 2006 | 04:28 PM
Z-man's Avatar
Z-man
Here's how I did it on my 400 block...
First, find the pad. There it is...right near that other thing...
Now drill a 27/64in hole.
Tap the hole with a 1/2-13NC die. (The tap and die are sold in kits and can be purchased at places like Home Depot.)
Insert the clutch pivot and tighten it.
And now.... (Actual results may vary...)
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what does that bolt up to??? the oil pan flange bolts or the bell housing bolts? i think it must be the bell housing bolts....
well then again maybe not ....wouldn't the oil filter would be in the way
Old Mar 3, 2006 | 04:44 PM
GDaina's Avatar
GDaina
Bellhousing....BB has the oil filter on the right side. I would think the sb has it on the right as well, else the clutch linkeage will hit the filter
Old Mar 3, 2006 | 04:56 PM
big_G's Avatar
big_G
SB and BB have the filter on drivers side. The bracket bolts to the bellhousing.
Old Mar 3, 2006 | 04:57 PM
Wrencher's Avatar
Wrencher
Great "how to", Z-Man! DO NOT forget that last step, it's crucial
If there's no boss, get the bracket.
Hans
Old Mar 3, 2006 | 04:58 PM
collectskulls
Z-Man very cool thank you pictures and all
Greg's Avatar
Greg
Just another Corvette guy
Jerry, That's the best photo-logue I've ever seen!
Old Mar 3, 2006 | 05:02 PM
SteveG75's Avatar
SteveG75
Or, go with hydraulic throwout bearing and get rid of the mechanical linkage totally.
Old Mar 3, 2006 | 05:22 PM
bobs77vet's Avatar
bobs77vet
ah thats the ticket...its above the oil filter.....i should have figured that out....good post i will have to try to remember that trick
Old Mar 3, 2006 | 05:50 PM
GDaina's Avatar
GDaina
I don't know my right from my left......
Old Mar 3, 2006 | 06:19 PM
Z-man's Avatar
Z-man
It's on the other side if you are standing in front of the car facing it, right?
Old Mar 3, 2006 | 06:22 PM
Z-man's Avatar
Z-man
Aww...shucks...it was nothing... :o
To Boy am I dumb
Old Mar 3, 2006 | 09:03 PM
bobs77vet's Avatar
bobs77vet
thats ok its part of getting old.....last night i walked out to the garage hit a patch of ice and wound up lying flat on my back....man that hurt....bouncing off concrete at 48 really sucks
Old Mar 3, 2006 | 09:06 PM
big_G's Avatar
big_G
And to think I left that **** many years ago just to have it be 85 degrees yesterday here in Austin,Tx.
Old Mar 3, 2006 | 09:08 PM
djcwardog's Avatar
djcwardog
I think SDP sells that in two lengths to cover various cars - just be sure to tell them you are dealing with a Corvette...
