700R4 Install Progress
It looks like the 2 3/4" I had the driveshaft shortened was about perfect. Bowties "Corvette Yoke" also required an offset u-joint.
The worst job probably was standing on my head installing the new brake light switch with the lockup cutoff.
One small problem I ran into was how to mount the trans temp sending unit. I went to my local parts store today and the guy led me right to a B&M tranny drain plug kit with a 1/8" plug which will fit the sending unit perfectly. I'll use plenty of red loctite here and maybe even weld the nut onto the bushing to be sure it won't ever work loose.
Besides some final wiring and TV setup I only have a couple bigger jobs left. One is to replace the Bubba rubber lines running all the way from the tranny to the cooler with steel.
The other job is to fabricate a new mounting pad on the tranny crossmember. The odd thing about the 700R4 is that although the tranny is almost 3" longer than the old TH400 the mount ends up around 3" closer to the engine. The good part is that the crossmember won't require any mods other than welding on a plate. Right now I'm glad I didn't spent the $200 (for Bowtie's crossmember) for a mod this simple. I'll try to snap a pic of what I do here.
So all in all it's gone pretty well so far. Now if it would just warm up to get rid of the snow and rain to wash all the salt off the roads.
http://forums.corvetteforum.com/show...570&forum_id=3
I'm hoping I won't have as much of a problem with this since I'm running 3.36 rear gears. Also I would think the tranny should downshift, thus disabling the lockup, before the lugging occurs. Maybe that depends on your particular transmission setup.
My tranny guy also got me a vacuum actuated lockup interruptor to disable lockup on acceleration. It may take some toying with to find the best vacuum location and possibly a vacuum delay so that it works at the right time.
It seems like it's the simple things that take the most time. I had to modify the bracket that holds the ignition-shift interlock cable to mount on the pan. Another fun one was getting the right brake lines and bending them for the tranny cooler. The tranny crossmember mount only took a couple of hours to fab up. I'm sure it will all be worth it but right now the anticipation is killing me.
She ought to be a real highway cruiser now. I figure between the overdrive and taking the bladder out of the gas tank I've probably doubled my range between gas stops from 150 miles to 300. That should come in handy this summer when the wife and I cross North Dakota and Montana on the way to Glacier Park and Banff. Next year maybe Niagara Falls and New England.
