surge tank overflow question please help
Old Mar 4, 2006 | 05:23 PM
war vette's Avatar
war vette
Default surge tank overflow question please help
bought a coolant tester,opened the surge tank,level was low,added water,started motor to circulate,re tested.Went for ride and had steam and coolant coming from overflow hose.Didnt fill over half.Could it be because maybe I didnt have the vent cap on correct.Also when i bought the car it ran hot around town.Changed tstat and it ran cool for a couple of months.Now its running hot again.any ideas?
Old Mar 4, 2006 | 08:37 PM
TexSon's Avatar
TexSon
Check the thermostat or just by a new one. They are cheap and install easily. Get that out of the way, and if it is still up and down, you may want to pull the radiator and have it professionally flushed. If there are still problems you might have a clogged gallery in your block. For obvious reasons, that is the last thing you should check.
Old Mar 4, 2006 | 08:52 PM
war vette's Avatar
war vette
I can do that but would the one that I just put in go bad already?Its only about 200 mi. on it
Old Mar 4, 2006 | 09:05 PM
694speed350's Avatar
694speed350
suspet the raditaor. could be partially clogged. also check with the engine running if you have bubbles in the cooling system.
Old Mar 4, 2006 | 09:12 PM
war vette's Avatar
war vette
Check for bubbles in the cooling system at the surge tank with the cap off?If so will do in the morning, thanks
Old Mar 11, 2006 | 07:33 PM
war vette's Avatar
war vette
It wound up bieng a faulty surge tank pressure cap
To surge tank overflow question please help
