Intake Manifold Question
Old Mar 6, 2006 | 01:26 PM
proracr's Avatar
proracr
Default Intake Manifold Question
What aluminum intake manifold could I put on my bone stock 1971 350/270 that wouldn't cause clearance problems with the original Quadrajet and dual-snorkel air cleaner installed? I am not looking for a big horsepower increase, just better appearance as the orginal manifold has discolored due to the heat channel through the center of the manifold which looks terrible. Thanks!
Old Mar 6, 2006 | 01:41 PM
LittleJake's Avatar
LittleJake
I was told I could run the 2101 Performer or the Edelbrock EPS without problems. Don’t go on my say though; let some of the more knowledgeable guys give you their opinions first.
Good luck!
Old Mar 6, 2006 | 01:45 PM
Ed Blue 03's Avatar
Ed Blue 03
The Torker II is one of the lowest profile manifolds.
Old Mar 6, 2006 | 07:59 PM
BigBlockk's Avatar
BigBlockk
The '78 to '81 Corvette intake manifold is aluminum. Get them on eBay from tome to time.
BigBlockk
Later.....
Old Mar 6, 2006 | 09:29 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
BigBlockk
Later.....
i have heard that but the one on my 79 l48 is ferrous and a magnet sticks to it....so i'm thinking its cast iron....
Old Mar 6, 2006 | 09:51 PM
694speed350's Avatar
694speed350
If you don't want to spend a lot of money and are satisfied with your current setup performance wise. pull the intake manifold clean it up repaint it and when you re-install it use an intake block off gasket to block the heat riser passage. old hot rodder trick. bythe way i think most of the aftermarket does not have the heat riser function. its to heat under the carb when cold to make the engine run smoother when cold start up.
Old Mar 6, 2006 | 10:53 PM
jackson's Avatar
jackson
MY1971 base sbc hood is low ... 3 Al intakes: Edelbrock Performer P/N 2101, Weiand Action Plus P/N 8004, Professional Products Cyclone P/N 52001. I have a good used (but dirty) Edelbrock Torker II P/N 5001 you can get CHEAP ... but that one has a Squarebore carb flange ... not the Spreadbore flange you need for Qjet.
Old Mar 7, 2006 | 12:17 AM
BigBlockk's Avatar
BigBlockk
I have manifold #14007378. This is listed for the '79 L82 and it is aluminum. I also have manifold #14057053. It is listed for '78 to '85 305 and 350 truck and passenger car and it is aluminum. At least a welding magnet won't stick to either one.
Just visually comparing the ports on these they appear identical.
BigBlockk
Later.....
Old Mar 10, 2006 | 11:48 PM
glen242's Avatar
glen242
I ran an Edel. Performer, stock Q-jet, and stock snorkel air cleaner on my '76 before I upgraded.
Old Mar 11, 2006 | 12:08 AM
comp's Avatar
comp
i have a couple stock alum. intakes
Old Mar 11, 2006 | 12:11 AM
Star79's Avatar
Star79
79 L-48 intake was/is iron. NHVette has my old one if anyone needs proof.
Old Mar 11, 2006 | 01:19 AM
81cali's Avatar
81cali
I have a performer 2101 that i got from ebay and still have not opened the box yet, also have a stock intake from an 81 that I just took out of the car yesterday.
Old Mar 11, 2006 | 11:51 AM
Jims79's Avatar
Jims79
BigBlockk
Later.....
I replaced the stock manifold on my 79 which was cast iron and weighted a ton w/the Eldebrook proformance.
Old Mar 11, 2006 | 02:55 PM
c3dreamer's Avatar
c3dreamer
I agree with the recommendations of 694speed350.
Old Mar 11, 2006 | 04:49 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i picked my aluminum Qjet manifold off of ebay for $40 and it's off an 81 Z-28
Old Mar 12, 2006 | 10:40 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Swapmeets are best buys.
I find plenty of Alum intakes on '70's camaros at the "Pick your own Parts" boneyards - usually <$20.
But at large swapmeets i have better luck as the intakes are already removed and can bargin for price. Now have plenty of Alum intakes (too many really) to play with and modify - 2 happen to be from late '70's vettes.
Happy hunting. cardo0
To Intake Manifold Question
