T56 swap
Old Mar 7, 2006 | 11:40 PM
bkarsten26's Avatar
bkarsten26
Default T56 swap
Has anyone done a T56 swap out of an LS1 f-body? I know Keisler is an option, but can get a used T56 for cheap. I am wondering what mods need to be done, including cutting, drivehsaft, clutch set up, etc? Thanks for any input.
Old Mar 8, 2006 | 10:15 AM
davidm_comp's Avatar
davidm_comp
I really want to make the swap to 6 speed too. If you do make the swap and need an extra hand I will gladly swing over with beer in hand.
Old Mar 8, 2006 | 10:25 AM
davidm_comp
Here is a site that has some good info:
http://temp.corvetteforum.net/c3/gwhite75/index.htm
Old Mar 8, 2006 | 04:07 PM
bkarsten26's Avatar
bkarsten26
I just cant see why it has to cost over two grand to do a conversion.
Old Mar 8, 2006 | 04:58 PM
Kalway's Avatar
Kalway
The shifter position is different, crossmember modification, drive shaft length. Lots of other things, also.
Old Mar 8, 2006 | 05:06 PM
enkeivette's Avatar
enkeivette
You are sooo the first person to ask this question.
You'll need an LT1 T56... do a search.
Old Mar 8, 2006 | 07:13 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Don't forget to beat the glitch and use the advanced search and check the "archives" box.
To T56 swap
