Compression choice
Old Mar 8, 2006 | 07:51 PM
hgm's Avatar
hgm
Default Compression choice
I am building a 383 for my 78. It will have .030 over KB pistons a with a Eagle crank. I will be running a Crane roller cam with .539 / .558 lift with ADV duration of 292. I am also installing 200 cc Dart pro 1 heads. The heads will have a little bowl work with gasket matching. Without milling the heads I will have a compression ratio of 9.8. My original intent was to run at 10.5. Been a long time since I have built a small block. Do you think the comp. ratio will make much difference? Any comments on the combination?
Old Mar 8, 2006 | 08:02 PM
Gordonm's Avatar
Gordonm
I am running a calculated 10.67 to 1 in my 383. I do have aluminum heads and am running a healthy solid flat tappet cam. I would run at least 10 to 1 with that cam. You are pretty close with what you have.
