water outlet 76
Old Mar 9, 2006 | 06:28 AM
original76's Avatar
original76
Default water outlet 76
Anyone know where I can buy a water outlet/thermostat housing for a 76 350? I've checked all my parts books, Chevrolet and parts stores. This neck has two bolt holes on the same plain, no taps for other connections, and triangle shaped indentations next to the bolt holes (one next to one bolt hole and two next to the other). The outlet is angled at about a 40 degree angle and goes towards the left side of the radiator.
Old Mar 9, 2006 | 09:26 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
No, I looked too when I put the stroker in mine. I wound up putting sensors in the intake manifold instead.
Old Mar 9, 2006 | 12:19 PM
vette4820's Avatar
vette4820
If you're referring to a thermostat housing, you can pick one up at Autozone for like $10. I got a nice chrome one that seems pretty solid. Fits my 76 nicely. Good luck.
Old Mar 9, 2006 | 12:21 PM
markdtn's Avatar
markdtn
The GM replacement has extra holes. If you want exact match, try Paragon.
Old Mar 9, 2006 | 05:20 PM
SanDiegoPaul
Not going to put the sensors in the housing, where he wants them.
Old Mar 9, 2006 | 05:59 PM
original76's Avatar
original76
I'll try autozone, but I'd still like to find one with the indentations like the original. I'd already checked Paragon who had up to like 74 and later than 78.
Old Mar 9, 2006 | 06:09 PM
rcread's Avatar
rcread
Is it this one from Napa?
http://napaonline.com/masterpages/NO...n=Water+Outlet
Old Mar 9, 2006 | 06:55 PM
original76's Avatar
original76
The cast iron neck with the two tapped connections is what the dealership sells as original as well as some of the other parts stores. The original is cast aluminum with no taps.
Old Mar 9, 2006 | 10:17 PM
76vette1's Avatar
76vette1
The original 76 housing had an EFE vacuum switch in it on both, L-48 and L-82 engines. I remember seeing thermostat housings with the bosses w/o tapped holes, but they were on earlier engines, 73 or 74.
Old Mar 9, 2006 | 10:24 PM
kdf1986's Avatar
kdf1986
Hello
Ecklers Part Number 32821 shows a 74-78 thermostat with a threaded housing for for emission controls.
kdf
Old Mar 10, 2006 | 07:09 AM
original76's Avatar
original76
Just to keep the records straight. I'm the original owner of this late year 76. The housing I described is the one that came with the car, no change has been made. There are no taps.
Old Mar 10, 2006 | 07:59 AM
markdtn's Avatar
markdtn
Probably going to have to go with used then. None of the ones Paragon has are visually correct? They will all bolt on to your intake the same.
Old Mar 10, 2006 | 08:36 AM
76vette1's Avatar
76vette1
That's not surprising. Back in the mid 70's, Engineering lost some of their control of their designs to the bean counters. The 76 Vette was almost a dumping ground for excess inventory, hence the rubber steering wheel, early and late radiators, and other subtle differences. In 77, GM was sued for putting Chevy engines in Oldsmobiles. By 78, the transformation of one body style to build a Chevy, a Buick, a Pontiac, an Oldsmobile and sometimes a Cadillac was in place. I was a Chevy mechanic at the time, and under the hood, they all looked the same.
To water outlet 76
