Front End
Old Mar 9, 2006 | 11:19 AM
will_2006's Avatar
will_2006
Navigator
Default Front End
Whats the difficulty of removing/installing a new front end assembly?
Old Mar 9, 2006 | 11:33 AM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
It veries on removal, depeds how rusted your front is. I personally had a heII of a time removing my siezed calipers. Are you going back to stock? Poly or rubber? Do an advance search, you will get alot of info.
Old Mar 9, 2006 | 12:59 PM
Dick72LT1's Avatar
Dick72LT1
How much do you want to remove? Steering? Suspension? Brakes? Power Steering? I've about completed my removal of everything and had issues all along the way, but have worked thru most issues. There's help here for everything.
Old Mar 9, 2006 | 01:01 PM
72LS1Vette's Avatar
72LS1Vette
The most difficult parts of a front end rebuild are the spring removal (not so much difficult as dangereous), removing the old control arm bushings, and removing the rivets that retain the ball joints and rotor (if you have original parts installed). If you search the archives you will find numerous posts on each of these topics. Good luck.
Rick B.
Old Mar 9, 2006 | 02:37 PM
will_2006's Avatar
will_2006
Navigator
Sorry let me rephrase i meant the fiberglass front end just the body not the cars front end sorry for the confusion. I do plan on overhauling the suspension and brakes. just trying to take it step by step starting with the body and interior
Old Mar 9, 2006 | 04:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
First question is: Why remove the doghouse? If you do not have extensive repairs to make, my advice is to leave the factory installation as is.
Part Two: removing the doghouse is not particularly difficult but there are things you want to plan for. Do your homework before you take the chisel to it. Lots of references on this subject through the aftermarket providers. Eckler's has a book; Glas-Ra has a nice How To. Buy a couple and thumb through them. You will also find the assembly instruction manual to be helpful.
Old Mar 10, 2006 | 09:13 AM
will_2006's Avatar
will_2006
Navigator
Thanks for the help i dont want to have to replace it but the guy who owned the car before me hit a deer and a good bit of it is broken off
Old Mar 10, 2006 | 11:40 AM
vetteboy1976kr's Avatar
vetteboy1976kr
Personally, I would pull off the front end, do my suspension work, then put the fiberglass back on. Things are easier without your head in a wheel well! The Glas-Ra book is pretty good. If you don't care about the front clip that is on there then you can chisel it off the cowl, just split the glue and no the cowl though. It is better to do it with the doors off also.
Old Mar 10, 2006 | 01:09 PM
Easy Mike's Avatar
Easy Mike
How extensive is the damage? You might be able to repair what you have without pulling the whole doghouse. Cheaper, too.
Old Mar 10, 2006 | 01:54 PM
will_2006's Avatar
will_2006
Navigator
well the on the left side half the front is broken off
from the fender to the hood and on the right side just a piece of the fender is broken off i thought about just doin pieces but because of the left side i think i need a another front end.
Old Mar 10, 2006 | 03:26 PM
Easy Mike's Avatar
Easy Mike
Sounds like minor fender repair and an upper surround panel would be the fix for you. Leave the fenders, inner fender panels, and hood on it and align the replacement upper surround panel with the OEM fenders and hood. Much less work.
To Front End
